Thread: How can I beat up on some fast German cars? (need 12's)
Results 1 to 20 of 21
  1. #1 How can I beat up on some fast German cars? (need 12's)
    Cambridge, Ontario Canada
    My buddies were mouthing off last night, one has a 2007 RS4 420HP & another has a modified 03 540i that dynoed 290rwhp & 340tq. Both guys are knocking on the 12's, very very low 13's around 107mph
    My mod list is in my sig, can I keep up or beat one of these guys with the following constraints:
    No nitrous
    No slicks
    No cam
    No weight reduction
    No trans work (until it blows - which it will eventually if I mod)
    Heads stay on
    I am thinking my variables are:
    Full size intercooler
    Ported Gen 3 S/C OR Gen V?
    Custom Tune
    Pulley down
    Throttle Body
    Any hope? Lets say a 2.0 60ft on street tires.
    2005 E55 - stock
  2. #2 Re: How can I beat up on some fast German cars? (need 12's)
    Mar 2012
    NC
    Step one...buy LSx powered vehicle (F-body if you will.)
    Step two...install normal bolt on crap.
    Step three...enjoy.
    This is quite possibly the easiest and cheapest way to go smack them around. Not trying to talk low about the W-body, but if you want to be fast...you're not exactly playing with the right platform.
  3. #3 Re: How can I beat up on some fast German cars? (need 12's)
    Minnesota
    Full size IC and a good tune will get you close pending driver mod
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  4. #4 Re: How can I beat up on some fast German cars? (need 12's)
    May 2008
    Schuyler, NE
    Pick yourself up a cheap Z7 or cartuning turbo kit and never look back. Without a cam and sticky tires, you are going to have a hard time hanging with them.
  5. #5 Re: How can I beat up on some fast German cars? (need 12's)
    Minnesota
    Theres always that option too^ lol but then your most likely going to be looking at a new trans shortly down the road. But you should be able to take them in a couple races first
  6. #6 Re: How can I beat up on some fast German cars? (need 12's)
    youre eliminating all the things that help the most and expecting the same results without them. will not happen
  7. #7 Re: How can I beat up on some fast German cars? (need 12's)
    May 2008
    Schuyler, NE
    Quote Originally Posted by Ricky21 View Post
    A turbo car is easier on the trans than a supercharged car.
  8. #8 Re: How can I beat up on some fast German cars? (need 12's)
    Short of a turbo, you have very little chance of keeping up.
  9. #9 Re: How can I beat up on some fast German cars? (need 12's)
    So full size IC, 3.1 pulley, tune, TB and Gen V might get me mid 13's given the constraints? Seems slow? The turbo option works better because the air is not as hot? Even with turbo I would still suffer from poor stock head flow & all the other constraints. Would the parastic loss of the SC be the reason why the turbo kit could hit the 12's?
    2005 E55 - stock
  10. #10 Re: How can I beat up on some fast German cars? (need 12's)
    new britain, ct
    turbo is way different build than an SC build.
    you could make more power on stock heads with a turbo kit than you can with ported heads and cam build on a supercharged car.
    i dont even think its the parasitic loss...i think its more due to the fact that the m90 is a horrible blower.
    07 Black GXP.
  11. #11 Re: How can I beat up on some fast German cars? (need 12's)
    May 2008
    Schuyler, NE
    Quote Originally Posted by Elite6 View Post
    With slicks and a good elevation, you could hit 12's. Without slicks, if you can drive, you're probably looking at low 13's at best.
    Heads don't affect a turbo much. It's no problem making over 600whp on stock heads.
  12. #12 Re: How can I beat up on some fast German cars? (need 12's)
    My sub 1.89 60 foot netted me a 13.8~ pass around 100 mph on a 3.5" pulley, 1.84 rollers, Open Cone, PEM's/3" DP & catback, stock tune IIRC.
    I did that on low psi 225/60/16's Bridgestone Potenza's in the fall and no headlight (I think I normally set the tires around 25~psi or so).
    Slicks and gutting it would change the program quite a bit, if the trans would take it...driver mod depending it should just fine, IMO. Someone here went mid 13's on a totally stock~ car with open headers, no catback, and slicks...and probably an intake. Can't remember but it's in the kills section here somewhere.
  13. #13 Re: How can I beat up on some fast German cars? (need 12's)
    Oct 2012
    Nowhere NY
    Get a RWD car with an LS
    a 400+hp fbody will be well into the 12s
    a 400+hp fibody with converter will be knocking on 11s
    Ive been medicating with burnouts and alcohol
  14. #14 Re: How can I beat up on some fast German cars? (need 12's)
    Quote Originally Posted by lsxftw View Post
    One other constraint, must be the car i own now.
    2005 E55 - stock
  15. #15 Re: How can I beat up on some fast German cars? (need 12's)
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    How to beat up on some fast German cars? Thats easy, just take a baseball bat to the German car and have your way with it.
    lol. jk
    I would suggest getting something with more power to start with. Probably something newer so there is less maintenance for right now. F-bodys as suggested would work. Or you could get the newer GTO and turbo it or something. That would be cool.
    Edit: Just saw it has to be your car. Ignore what I said.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  16. #16 Re: How can I beat up on some fast German cars? (need 12's)
    Oct 2012
    Nowhere NY
    oh booo
    ok i have a friend who has a 01 gp with about a 100 shot of nitrous with DRs and he nets high 12s
    He also has a built tranny, meth, and engine work done
  17. #17 Re: How can I beat up on some fast German cars? (need 12's)
    Ontario
    oh booo
    This pretty much. Throw some spray in there and have your fun. Just know that it comes with a high risk.
  18. #18 Re: How can I beat up on some fast German cars? (need 12's)
    Oct 2012
    Nowhere NY
    ^^^ its not a high risk if you set it up right and have enough fuel, granted you have access to your tune
  19. #19 Re: How can I beat up on some fast German cars? (need 12's)
    Quote Originally Posted by Oxfire View Post
    You end up selling that turbo kit?
    2005 E55 - stock
  20. #20 Re: How can I beat up on some fast German cars? (need 12's)
    Feb 2009
    flintnasty MI
    If I ever ran on street drag radials I wouldnt have had too many problems running 11.8 on my old turbo gtp setup.
  1. That is a fast Grand Prix, I don't think they were meant to go that fast
    By Explicit_Spade in forum Off Topic Discussion
    Last Post: 07-04-2011, 11:32 AM
  2. Exteremly Fast Cars, DRAG!
    By KawaFord in forum Off Topic Discussion
    Last Post: 01-25-2010, 05:37 PM
  3. Training my dog in German. Video!
    By TDCRacing in forum Off Topic Discussion
    Last Post: 10-17-2008, 08:01 PM
  4. A GERMAN joke
    Last Post: 07-13-2008, 09:54 AM
