Thread: Advice on Street Building my GTP
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
  1. #1 Advice on Street Building my GTP
    GT Level Member Dakoda's Avatar
    Feb 2013
    Illinois
    Hi im just looking for good routes to go as far as gaining more power. This is going to be for a DD so nothing to crazy. Right now all thats done is a zzp downpipe and plog with a 3.5 pulley...
  2. #2 Re: Advice on Street Building my GTP
    Ohio
    zzp tune or custom?
  3. #3 Re: Advice on Street Building my GTP
    Feb 2013
    Illinois
    ill probably end up going with a zzp tune... not set on the idea it just seems easier and cheaper
  4. #4 Re: Advice on Street Building my GTP
    Ohio
    no im saying why arent you tuned yet?
  5. #5 Re: Advice on Street Building my GTP
    Feb 2013
    Illinois
    i just bought the car saturday with all of this already done...
  6. #6 Re: Advice on Street Building my GTP
    Ohio
    ohh i gotcha. yeah, get either a scan gauge or an aeroforce first to scan your different parameters so you know how well or how bad its running right now. stay off too much throttle as well.
  7. #7 Re: Advice on Street Building my GTP
    Feb 2013
    Illinois
    ok... where are some good websites for those parts? I did notice that when i give it full throttle it seems a little sputtery not bad though
  8. #8 Re: Advice on Street Building my GTP
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Sputter could be knock.
    Get an Aeroforce or a Scan Gauge II to read KR and other parameters.
    Also you need a tune, find some one local that will do it, or email Overkill with your mods list and they will custom tune your PCM.
  9. #9 Re: Advice on Street Building my GTP
    Stock tune should be fine with a plog/dp and 3.5 as far as fuel goes. They tend to run somewhat rich already.
    But knowing if the car has KR is something you'll want to know about. A tune will just help with a few small aspects as of right now because those mods arent very serious. I'd suggest not buying a ZZP tune and going with a different vendor or a custom tune.
  10. #10 Re: Advice on Street Building my GTP
    Feb 2013
    Illinois
    why not zzp?
  11. #11 Re: Advice on Street Building my GTP
    Jun 2011
    Cause there are better tunes out there.
    Custom, in car tune, is the best.
  12. #12 Re: Advice on Street Building my GTP
    Ohio
    zzp does not have the greatest can tunes
  13. #13 Re: Advice on Street Building my GTP
    Cambridge, Ontario Canada
    Don't pi$$ around, get Speed Daddy headers
    2005 E55 - stock
  14. #14 Re: Advice on Street Building my GTP
    Feb 2013
    Illinois
    ok is it expensive to do a custom tune? also i want to point out that i fixed the stuttering with a solenoid and vacuum lines that were butchered... really need an alignment though. and I'm probably going to do sway bars and links before motor work.
  15. #15 Re: Advice on Street Building my GTP
    May 2008
    Schuyler, NE
    ZZP tunes are fine. Anyone that tells you different has probably never seen how similar they are to WBS, DHP, 3800performance, Intense, Overkill, etc...
  16. #16 Re: Advice on Street Building my GTP
    Feb 2013
    Illinois
    ok aside from the tunes... which route should i go as far as fuel, intake, pulleys, exhaust, etc...
  17. #17 Re: Advice on Street Building my GTP
    Never Never Land
    ZZP canned tunes suck. Period. There was a scenario where someone had MORE knock with a ZZP tune than they did a stock tune.
  18. #18 Re: Advice on Street Building my GTP
    Which brings about the point, they're a waste of money.
    Even street tunes can be pointless.
    The only things you'll ever notice are the transmission settings.
    Mechguy had a reptile PCM which caused more KR than his stock PCM.
    He finally gave up and pullied up IIRC.
    Quote Originally Posted by Dakoda View Post
    You're not going to get much better performance without dropping a bunch of cash.
    Just enjoy your car as is and don't worry about.
    This is all assuming you've already monitored for KR under numerous conditions for an extended period of time.
  19. #19 Re: Advice on Street Building my GTP
    Never Never Land
    Fuel-stock system will be fine. Just be sure to run 91 or better octane.
    Exhaust-speed daddy headers. Stock cat back unless you want it to sound like shiit.
    Intake-make one
  20. #20 Re: Advice on Street Building my GTP
    Feb 2013
    Illinois
    improbably just gonna make an intake and get headers for now... im not worried about knock, seeing as how i have like no mods done..
  1. Building My Own Intake
    By DanPrixGTP in forum General Tech Discussion
    Last Post: 02-04-2012, 11:47 AM
  2. Building my bro a PC.
    By Odi in forum Off Topic Discussion
    Last Post: 01-07-2012, 04:41 AM
  3. Help with building a sub box
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 05-27-2010, 11:35 AM
  4. Building a 93 pro street grand prix n have a chassis ?
    By lukeeep in forum Brakes/Suspension/Chassis
    Last Post: 03-28-2009, 08:01 PM
  5. Building Cold Air
    By SLO-6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 09:33 PM
