Thread: DIY: brake/fuel lines
Results 1 to 5 of 5
  1. #1 DIY: brake/fuel lines
    SE Level Member PTGsDaytona500GTP's Avatar
    Jul 2010
    Broadview Hts Ohio
    Recently discovered that i am leaking brake fluid from my lines running underneath the driver side. I took it in to get it checked out and was told that not only do my brake lines need to be replaced but so do my fuel lines because of how corroded they are. I was qouted 1000$ plus and to be honest i cant afford that at this point in my life so i absolutely need to do this myself with my brother so i can save money. Anyone who has exp with this? Degree of diffuculty? What parts i need? Where to get the parts? I really love my gtp and would hate to get rid of it.
  2. #2 Re: DIY: brake/fuel lines
    Honestly not bad.
    Head to your parts store and pick up a bag of the bulk fittings for the brake lines. IIRC they are on the PA labeled premade lines, that way you can find the sizing. Then figure out what the fuel lines need to be as well. Except realize you can't put a union (legally AFAIK) in a fuel line. So you'll need a way to get around that (I'd go braided at the end ..see the how to braided line thread). I strongly recommend the NiCopp or Connifer line. It's much easier to bend than the steel stuff. It also should never rust out again, the steel only has a coating on the outside. it's more expensive, and so much nicer.
    Buy a decent flare/double flare tool. I got mine at Sears, it's about a $50-$65 craftsman and it works great every time.
    Then watch a couple youtube vids on flaring and double flaring.
    Jack up the car and you'll have a few hours under there.
  3. #3 Re: DIY: brake/fuel lines
    HUDSON
    It is not hard at all to make nice lines and flare ends, the key is to be patient and take your time making the bends and the double flares, don't buy a cheap flare tool either, you don't need the most expensive either, just get a qulity dauble flare tool and practice first. SOme lines under the GP neeed to be two pieces to make it much easier to install, just use a union to join them, it save alot of time and aggrivation than trying to snake one long line into place. I had to do this on the rear brake lines of my GTP.
  4. #4 Re: DIY: brake/fuel lines
    Nov 2011
    NY
    Part Detail
    BRAKE LINES (JL9) - W
    Links to the parts if ya want it premolded... I don't know, just thought it might help.
    But $1,000?!? I'd do it myself too! Amd so can you.
  5. #5 Re: DIY: brake/fuel lines
    Jul 2010
    Broadview Hts Ohio
    And how much do you think this will cost me? Fuel/brake lines everything? Thanks fornyour time.
  1. Pre-bent Brake Lines vs Bending Custom Lines
    By Elite6 in forum General Grand Prix Discussion
    Last Post: 08-31-2012, 07:26 AM
  2. Rusted Brake Lines
    By GaBear in forum Brakes/Suspension/Chassis
    Last Post: 01-08-2012, 09:13 PM
  3. Brake Lines
    By siupilot in forum Brakes/Suspension/Chassis
    Last Post: 08-10-2010, 09:34 PM
  4. It's not the P.O.S ss brake lines?
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 01-20-2009, 09:09 AM
