Thread: Long crank in the mornings....
Results 1 to 6 of 6
  1. #1 Long crank in the mornings....
    Sep 2012
    AZ
    Recently I've notice on cold mornings, after letting the fuel pump prime, it will crank long then start to want to start over but acts like I'd need to pump the pedal as If I had a carb. If I turn if it off then crank again, starts normal. Also noticed my freeway mpg have dropped to bout 20 mpg (don't know if it matters).
    It's a 04 gtp w/ new plugs and wires.
    Any idea on where I should start?
  2. #2 Re: Long crank in the mornings....
    You can try cleaning the throttle body and MAF sensor with the correct cleaners. I bet the TB is all nasty and black.
    What brand plugs did you buy?
  3. #3 Re: Long crank in the mornings....
    Sep 2012
    AZ
    Okay, I'll try that, thank you. I forgot what brand but they were the ones from the factory, made sure of that.
  4. #4 Re: Long crank in the mornings....
    tennessee
    clean ur iac valve while ur in there it controls cold starts
  5. #5 Re: Long crank in the mornings....
    Feb 2009
    flintnasty MI
    IDk about you but I have a long crank almost every morning...
  6. #6 Re: Long crank in the mornings....
    Dec 2010
    DMV
    Zing!
  1. No crank, just click. Replaced starter, still no crank.. help!!
    By Steve98GTP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-17-2013, 08:48 PM
  2. No crank. Replaced starter, still no crank. Now what.
    By suctoes in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-13-2013, 01:22 AM
  3. E85 hard start in mornings or after sitting a while
    By LapeerGTP in forum PCM Tuning
    Last Post: 08-06-2012, 11:28 AM
  4. 02 Grand Am wont start in mornings
    By Madness in forum Off Topic Discussion
    Last Post: 06-27-2011, 05:11 PM
  5. long crank no start but has spark
    By vamber58 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 02-05-2011, 07:10 PM
