Thread: Rocker Shims
Results 1 to 3 of 3
  1. #1 Rocker Shims
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    anyone have a source for rocker shims to correct valvetrain geometry other than the zzp spacers for their heads? I need like .040", and I was hoping not to have to buy new pushrods. If anyone knows what kind of shim I could use under the rocker pedestal to shim it up that amount, let me know. Thanks!
  2. #2 Re: Rocker Shims
    they sell "feeler gauges" at the parts store, thin sheets of metal marked with the thickness. its how were used to gap spark plugs before all the cool gap tools came out.
    these will also work on top of the spring and under the rocker arm.
  3. #3 Re: Rocker Shims
    Feb 2009
    flintnasty MI
    anything flat will work..
    Why do you need to shim your rockers? Using LS1 valves?
  1. What size shims to use in shift kit ??
    By jsnyder49090 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-26-2012, 09:47 AM
  2. rocker help
    By BoostedComp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 08:45 AM
