Thread: Supercharger sound..
Results 1 to 20 of 25
  1. #1 Supercharger sound..
    SE Level Member azmattaz06's Avatar
    Feb 2009
    Tucson
    So the last few says it started making a sound and me thinking its the Coupler got a new one to change it out but my old coupler was fine, still making the sound very loud, it's not coming from the nose, would I need a whole new supercharger?
  2. #2 Re: Supercharger sound..
    Feb 2009
    Tucson
    Also would a supercharger from a 95 Rivera fit? Excluding the nose because those are short. Thanks
  3. #3 Re: Supercharger sound..
    Florida
    The 95, no. What year is your car? assuming its a 97-03, in which case you need a Gen 3.
    What kind of noise is it making? Rocks tumbling is the coupler. Take the belt off and see if the pulley has any play in it.
    Could have possibly injested something, and chipped a rotor. Also, needle bearings could be shot.
  4. #4 Re: Supercharger sound..
    Feb 2009
    Tucson
    Well just removed the belt and started it and same sound.. Like metal, car runs fine, also sound kind of goes away with AC on.. I'm confused
  5. #5 Re: Supercharger sound..
    Florida
    Can you take a video of it?
    Metal doesnt really make a sound, it just sorta sits there....
    Is it a scraping sound, grinding, or is it a clanking sound?
  6. #6 Re: Supercharger sound..
    Feb 2009
    Tucson
    I'll do a video of the car right now. Give me a few, thanks
  7. #7 Re: Supercharger sound..
    could be a bad a/c clutch. take the other belt off see if it goes away as well.
  8. #8 Re: Supercharger sound..
    Florida
    My 02 GTP would make a bad knocking noise...thought I had rod knock. Ended up being the A/C Clutch. if I turned the AC off, it went away. Back on, it'd start knocking. Though sometimes they do grind while free spinning.
  9. #9 Re: Supercharger sound..
    Feb 2009
    Tucson
    About the 40 second mark you can hear it good.
    GTP sound - YouTube
  10. #10 Re: Supercharger sound..
    Florida
    Okay, so it's a rattling noise.
    Pop the other belt off, see if it goes away. If it does, it's either the AC gone bad, or possibly a totally shot tensioner (they chatter like that once they go bad)
    Look at the tensioner where the alternator is mounted. Is it bucking back and forth?? There's a chance that it could be the S/C and the rotors are hitting each other a little, but I would think that noise would be faster.
    Get a long wrench or screwdriver, and put one end against various parts of the engine, and the other end against your ear. It will transmit the sound like a stethoscope. (please dont use the pointy end of anything against your ear)
    Do that to the S/C, tensioners, LIM, etc, until you find where it is the loudest. Then, try to isolate exactly where it's coming from.
  11. #11 Re: Supercharger sound..
    Feb 2009
    Tucson
    Will try and get back thanks !
  12. #12 Re: Supercharger sound..
    Florida
    Yep, just be careful. Dont get fingers/hair stuck in spinning things.
  13. #13 Re: Supercharger sound..
    Out West
    Change tune to drop A/C past 50% throttle.
    Whine with your Cheese?
  14. #14 Re: Supercharger sound..
    Florida
    That GP has been gone for years
  15. #15 Re: Supercharger sound..
    Feb 2009
    Tucson
    Well I took off the belt and felt the crank and AC, there's some movement in the crank pulley not much but some, I can turn the crank a little hit with my hand idk if that's supposed to happen the AC pulley is kind of weird it has little metal parts I can move and it makes sound but doesn't seem like that's abnormal.. Could it be my crank?
  16. #16 Re: Supercharger sound..
    when you say the crank moves, in what way, like you turned the engine some? <<<normal
    or side to side play or in and out play?<<<<<not normal
  17. #17 Re: Supercharger sound..
    oh the a/c clutch, the part the belt rides on should turn, they dont always spin smooth sounding, but it should snug.
    the center of it should not turn freely. thats the compressor part, it only spins when the a/c is on.
    if you turn the a/c on and the noise goes away its the clutch bearing going bad. and you would need a new compressor.
  18. #18 Re: Supercharger sound..
    Feb 2009
    Tucson
    Well the sound is horrible when starting the car it has loud metal clunking, the crank moves in and out just a tad, I have a bad feeling it that because of how bad the sound is. The sound goes down a considerable amount when the AC is on but not but not completely gone.
  19. #19 Re: Supercharger sound..
    unless the balancer on the crank is shot. like the pulley part turns on the mounts or its loose. it sounds more like the a/c clutch.
    post up a vid if you can, that helps sometimes. lots of ears.
  20. #20 Re: Supercharger sound..
    Feb 2009
    Tucson
    I posted a vid in this same thread, I can do another since the sound has gotten worse in my opinion
  1. can you make supercharger have turbo blowoff sound?
    By DrSnazzy in forum General Tech Discussion
    Last Post: 06-25-2012, 12:11 AM
  2. Grinding sound when making sharp left and awful creak sound when going over bumps
    By rescuetoaster in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2012, 10:06 PM
  3. Supercharger coupling OR Supercharger belt tensioner?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 07-23-2010, 11:56 AM
  4. Will a 2001 Bonneville supercharger work on a 97 gtp?supercharger swap
    By Bunique7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2010, 08:39 PM
  5. supercharger deep sound
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2009, 05:00 PM
