theres this annoying vibration my car has been doing for a while at around 1600ish rpms. its always when im a little bit on the throttle at this rpm... anyone know what it could be?
Last time you had a tune up?? (slight miss due to dirty plugs)
could be an engine mount
im doin new plugs soon, but when i scanned the car i had no misses
x2 on the engine mounts, I had the same issue a few weeks ago, swapped my wires and plugs and most of the stutter went away but I still had some. Checked my mounts and they disintegrated when I touched them! Replaced them and no more problem!
I probably will go with some Poly mounts but I felt the need to get some mounts on their asap so OEM I could get immediately.
where exactly is the motor mount? is it hard to replace?
There are 4 of them on our cars....the 2 on top, the one that is located on the inner side of the drivers side inner fender flap, and the one that is pretty much located under the harmonic balancer on the passenger side. All of them are relatively less than difficult to change.
Good luck
ok, and i should replace the 2 on bottom right? because the 2 dogbones seem to be fine
I would recommend it. From what you have described, motor mounts are the common problem. They come with a lifetime warranty from Auto Zone.
