Thread: New radiator?
Results 1 to 3 of 3
  1. #1 New radiator?
    Sep 2011
    Detroit, MI
    I have an 02 grand prix gtp. I've replaced the supercharger gasket the lower intake manifold gasket the thermostat and ects, as well as a few other related parts. Now my car is running hot but the heat just blows cold air. I had a coolant flush done in a shop about a year ago but could I need another one? Could the radiator be bad? Help! Fed up with coolant system...
  2. #2 Re: New radiator?
    Pennsylvania
    Have you looked at the heater core? I mean, if the gauge on the dash is showing that it's heating up then you have the heat, you're just not getting the heat to the vents.
    When did the lack of heat start? You could have put air into the system and it's stopping flow to the heater core. Could also be that the mechanism that directs air through the heater core is not working and it's just pulling outside air in.
    Sport Edition Kv5 18x8
  3. #3 Re: New radiator?
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Bleed the coolant, you might have air in the system. If that doesn't help, it's probably the heater core.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  1. Gt radiator fit GTP?
    By Momof2 in forum General Tech Discussion
    Last Post: 10-30-2012, 11:01 PM
  2. 2-row radiator from 04-08 gp
    By TEK310 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2012, 03:35 PM
  3. Radiator help
    By Jordan Flowers in forum General Grand Prix Discussion
    Last Post: 06-22-2012, 09:54 PM
  4. radiator
    By blown gt in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-14-2010, 09:17 PM
