Thread: HELP need opinions
Results 1 to 13 of 13
  1. #1 HELP need opinions
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    i have fixed all possible vacuum leaks and my ltft is still pegged at 16.4 at idle. MAP reads 11.25 inhg. maf is healthy only other thing i could think of is a MAP is bad opinions?
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  2. #2 Re: HELP need opinions
    Do you have a mechanical vacuum gauge hooked up?
  3. #3 Re: HELP need opinions
    Sep 2012
    bridgeport,NY
    im trying to get one
  4. #4 Re: HELP need opinions
    Sep 2012
    bridgeport,NY
    i have a lsm1 scan tool are there any other values that could help
  5. #5 Re: HELP need opinions
    MAP should read around -19 to -20 at idle.
  6. #6 Re: HELP need opinions
    Sep 2012
    bridgeport,NY
    bad map sensor, i guess i wont know till i get a vacuum gauge
    SE Level Member Rob97gtp's Avatar
    Jul 2012
    Kansas city
    Have you checked fuel pressure? It could be low and attempting to fuel it more due to lack of fuel pressure.. Also could have low fuel volume
  8. #8 Re: HELP need opinions
    Sep 2012
    bridgeport,NY
    fuel pressure is good round 55 psi i have a map sensor of a 3.4 l im gunna try tommorow. just gotta get the connector to go in. and im gunna get that vacuum gauge and test that
  9. #9 Re: HELP need opinions
    Sep 2012
    bridgeport,NY
    well map sensor is good. i deleted the egr today and now rpms bounce like crazy at idle, but my map reading is where it should be. i unplugged the MAF sensor and it smooths out at idle and will sit at 1500 rpm. is it time for a new MAF sensor?
  10. #10 Re: HELP need opinions
    Tried cleaning it yet?
  11. #11 Re: HELP need opinions
    Sep 2012
    bridgeport,NY
    ya ive cleaned it 4 times now
  12. #12 Re: HELP need opinions
    Know anyone around that'll let you switch out mafs to see if yours is actually bad?
  13. #13 Re: HELP need opinions
    Sep 2012
    bridgeport,NY
    not at all imtrying to track some one down
  1. Need opinions on this.
    By cameron92 in forum Visual/Body Modifications
    Last Post: 01-11-2012, 08:25 PM
  2. Opinions on N* TB please
    By wpbboy81 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2011, 07:36 PM
  3. opinions
    Last Post: 03-30-2011, 12:58 AM
  4. opinions on blu-ray dvd
    By DaytonaGTP in forum Off Topic Discussion
    Last Post: 02-03-2011, 11:28 PM
  5. Opinions
    By ZR1Vette09 in forum Visual/Body Modifications
    Last Post: 01-06-2010, 11:05 PM
