Something smells fishy... :sly:
Sent using my Galaxy SIII on Tapatalk 2
Take the intake off, bust up the gasket a bit and let her drink the radiator dry? Lolz
when cash for clunkers was going on we would drain oil and put in a mix that would garuntee death, This was fun taking bets and such to how long they will run. ive seen cars drive 1/4 mile then die and some that die instantly
are you sure your not just trying to destroy somebodies car that you don't like?
Put it on block go WOT with no oil or coolant like everyone was saying along with tossing in some small screws, try some M80's as well
Nickell, that's what it kinda sounds like lol
I wanna see big boom
Sent from my DROID RAZR using Tapatalk 2
Want to make it go boom? ... Might have to settle for clank and clunk.
All you really need to consider is removing the rev limiters and stuffing it to the floor. Our motors don't like high rpm for extended periods of time.
video is a must.... and my vote is that you crash it into a few trees, then throw small nuts down the intake and maybe a m80 would be nice on a long fuse stuffed in to the filler neck.... yes thats my vote... LET THERE BE BOOM
Anything in the gas tank and it will just stall out, most likely without damaging anything in the engine other than maybe the fuel injectors. You really want to lock it up and possibly blow a rod out of the side of the block pull the break booster hose off and stick it in a gallon jug of water or something and blip the throttle a few times.
Let my 18 year old son drive it.
Promise to use your powers for good in a safe environment... like a remote start, or I won't mention that ammonium nitrate might do the trick.
Oh, and sugar has only been proven to do absolutely nothing to gas a few times over.
