Recently had a motor swap done this weekend due to bad bearing. Drove it home and everything seemed ok. Wanted to cut out on the highway but never died. Got home and the problems started. Car idles at 2000RPM, slams into gear. I can drive it down the street but it wont shift out of 1st gear. Trans was never an issue, so I don't think anything is wrong with it. Aeroforce will also shut down randomly now, auto lights will flicker. Checked battery cables and all is well.
Mods: L67 w/S1x cam, Gen3 w/3.4, N* with a MAf that needs replacing but wasn't an issue on my other motor.
No misfires are showing even though it isn't really idling smoothly, sounds like a damn helicopter
TPS looks to be functioning properly from what Aeroforce reads
I unplugged IAC and idle dropped but then slowly crept back up
Also Triple checked all plug wires... Need some suggestions on what I should be checking. I'm confused as to why it won't go out of 1st. If I can solve that I can at least drive it to work where the rest of my tools are, or to Bill's. Don't really want to use another tow. Thanks in advance for any input!!
