Thread: E-85 and pulley.
Page 1 of 3 123 LastLast
Results 1 to 20 of 48
  1. #1 E-85 and pulley.
    GT Level Member riceburner's Avatar
    Aug 2008
    denver, co
    just a quick question, but if i have plugs, 180* "d" themostat, intake and plog. would running e-85 allow me to drop the pulley and to what size?
  2. #2 Re: E-85 and pulley.
    Banned
    Wichita Falls, Texas
    You cannot run E-85 without extensive modifications.
  3. #3 Re: E-85 and pulley.
    you dont need extensive mods, just the right ones.
    youre going to need bigger injectors and a tuner. basically it. everything else in the car is pretty much up to snuff. everyone says the gas tank and fuel lines are a problem since ethanol is "corrosive" but its not. take a chem class and youll know what im talking about.
  4. #4 Re: E-85 and pulley.
    Barksdale AFB, LA
    It does cause certain rubber seals to degrade. Only an issue in older cars since newer cars have synthetic seals designed to cope with ethanol (because most gas is now 10% ethanol anyway).
    2009 Subaru Impreza WRX STI
  5. #5 Re: E-85 and pulley.
    yup yup.
    ive got 65# injectors waiting to get dropped in so i can test out this e85 fad. ill only stick with it in the summer though. i need all the mileage i can get in the winter.
  6. #6 Re: E-85 and pulley.
    Aug 2008
    denver, co
    i am aware of the modification needed and will do the tune, injectors, pump and probably some shiney fuel logs!
    im just curious if i can run like a 3.5 with the 105 octane and cooler charge?
  7. #7 Re: E-85 and pulley.
    im hoping to run a 2.8 with no intercooler on my setup with e85, but im not dropping any lower than me being able to run 18* of timing.
    im hoping my pump will keep up, those are expensive to upgrade.
  8. #8 Re: E-85 and pulley.
    Aug 2008
    denver, co
    so with just plugs, therm, and plog with e-85 what size pully do you think i could run?
  9. #9 Re: E-85 and pulley.
    probably a 3.4 knock free. id get a downpipe on top of that so you dont start boost stacking. got the u-bend out already? do that if nothing else. intake done? do that too.
  10. #10 Re: E-85 and pulley.
    Aug 2008
    denver, co
    OH YA sorry. i hav a K&N intake,and the u-bend is gone already too!
  11. #11 Re: E-85 and pulley.
    get a downpipe, rockers, and some bigger injectors and im sure youd be able to run around a 3.25 or so, but who knows cause i havent tried it yet to see.
  12. #12 Re: E-85 and pulley.
    Aug 2008
    denver, co
    im not trying to drop real low. its my dd. but i would like to beat f-bodys to give me some street savy! ;-) maybe high 13's you know. not to much
  13. #13 Re: E-85 and pulley.
  14. #14 Re: E-85 and pulley.
    Aug 2008
    denver, co
    my ls1 bird stock ran 14.6's...
  15. #15 Re: E-85 and pulley.
    Banned
    oswego
    No way you can run a 3.25 with E85, maybe a 3.4 but i'll bet you'll still have knock. I have more mods than you and meth injection on top of that and i barely can run 3.20 pulley, but i also run 21* of timing and have better e.t.'s than anyone with my mods.
    bio248.... running a 2.8 pulley with your mods on e85 is going to result in a blown engine. I wouldn't suggest it, not even thinking about it. E85 doesn't have the effect you guys might think it does without an inter cooler. If you really want to see the good effects of e85 get an inter cooler or a high compression bottom end. It might say i'm a newb because i don't post here a lot but trust me i know what i'm talking about.
  16. #16 Re: E-85 and pulley.
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by Mikegotone'02 View Post
    I just wanna touch up on something here.....before I did the meth injection, I was running a 3.2 on the street...3.0 at the track on 92. Now, with the kit I'm running a 3.0 street and 2.8-2.6 at the track. It can be done with supporting mods, and it's all in the tune.
    And back before headers I had stock mani's with a 3.25.....so I can't see why E85 won't help out by quite a bit, but altitude does play a pretty big factor in NA cars....not quite as much with forced induction.
  17. #17 Re: E-85 and pulley.
    Banned
    oswego
    Quote Originally Posted by Reptile View Post
    Well on e85 i run a 3.2 with less mods than you and ran a 12.82... it is beneficial but again, pulley size has nothing to do with how much power a car makes, the tune does. I can throw a 2.8 on my car and run 10* of timing all day long if i wanted. So far with no i/c, no cam, stock blower, tb all that stuff I've trapped 106.23mph with no juice. On the juice I'm at 115.72 ohh, it's a dry shot too. When are you people going to get the pulley size doesn't f-in matter!
  18. #18 Re: E-85 and pulley.
    Banned
    Quote Originally Posted by riceburner View Post
    Poor driver.
  19. #19 Re: E-85 and pulley.
    Banned
    oswego
    Quote Originally Posted by Street Wolf View Post
    Poor driver.
    x2 that's pretty slow... ls motors are known for their insane top end, but 14's.... You'll need a little more help than that to give an ls car a run for its money unless it's a simple bolt on gto, those are slow as balls lol to heavy!
  20. #20 Re: E-85 and pulley.
    Banned
    Lmao, I agree. GTO's suck, but if it's a Camaro or a Trans Am with a LS1, there should be no reason (Other than a bad driver) that the car should'nt be able to run anywhere from a low to mid 13.
  1. 3.5 SC pulley on 07 GP/GT
    By 07 GPGT in forum General Tech Discussion
    Last Post: 03-27-2009, 11:23 PM
