Re: Vacuum line hack job, explain to me why or if they were on to something
It does, I got the car running, It runs great! w/out all the vacuum lines or evap system...I had to tie in the vac line from the firewall onto the manifold to get the hvac controls to work...Ive realized there isn't any part of this car that hasnt been hacked apart...
Not sure where the line would run Erik. I've never found an SC car w/o it. Because when you boost, you lose vacuum.
OP: at least you know it'll be a constant puzzle to solve.
pics of said vac lines?
Im just curious as to what it looks like
what runs the boost gauge on the dash?
The pcm via the map sensor IIRC.
