Thread: P0420 Code keeps setting on 2001 GTP
Results 1 to 4 of 4
  1. #1 P0420 Code keeps setting on 2001 GTP
    Nov 2008
    Hi there! First post for me, so I hope to make it an interesting one!
    My 2001 GTP has begun to set the P0420 Cat Efficiency code. Of course when I reset the PCM all the Readiness Monitors get reset too, which is a problem when I take it to testing for Emissions. The vehicle has 124K miles on it and very well maintained and in excellent running condition. It started setting this code about 2 months after I put a new Catco cat on with Bosch O2s. Initially I'm thought it could be either the cat or the O2s, so I replaced them both, the cat is now a Magnaflow and the O2s are GM. The rest of the exhaust is stock along with the engine except for a 180 thermostat & 3.4" pulley.
    So, enough history, here is the data. According to my Snap On SOLUS, the code gets set after 100 miles or so of daily driving. It is set at idle, in drive, at 0MPH, minimal LT & ST trims, 180 ECT, 10 to 13inHG MAP, TPS @ 0% and calculated A/F at 13:1. What is wierd about the data is the MAP value and A/F ratio. Normal running when I check it, the MAP is 18inHG or higher with a 14.7:1 A/F. I can't figure out why it would only set this code after driving a while, several ignition cycles later, and how it correlates to the low MAP and rich mixture values. I'm hoping with all the smart people on here that someone might have some ideas. Anything is worth looking into.
    Thanks a lot for reading this and helping out a fellow GTPr
  2. #2 Re: P0420 Code keeps setting on 2001 GTP
    GT Level Member 98daytona500's Avatar
    Nov 2008
    st louis
    bad idea goign with bosch o2 sensors.. stick with stock type
    plus if thats a high floow cat u ill have the light problem as well get a aftermarket pcm or tuner and remove the 420 code and ur done
    99 buick regal gsx..headerz, 3" motor back exhaust , lowered on B&G springs, transgo shift kit, solid offset front motor mounts, 3.2 mps, fuel pump rewire, zzp h/l cam, tinted headlights and tails, 5% tint all around zzp s2 alt booster, alt rewire, al103, jmb, ported blower, machined lim
  3. #3 Re: P0420 Code keeps setting on 2001 GTP
    Yes, if you get a high flow cat the sensor actually won't sense the cat there, and will throw a code. If I were you I'd get a Denso o2 from ZZP, tried and true, they are hella good. Plus, if you are running a 3.4" pulley with a high flow cat and a 180* T-Stat and no other mods you probably have A LOT more to worry about...
  4. #4 Re: P0420 Code keeps setting on 2001 GTP
    Nov 2008
    Thank you for your input. The PCM senses the catalytic being there since I can watch the cross counts and input voltage from the rear O2. It is a very specific condition as to when the code is set, that being at idle, in drive, 0% TPS, etc. I have been running the minimal vehicle mods for 120K miles, no issues until now. It does have an ASCD ram air hood with the SLP ram air cold induction kit. Normal improvement stuff like MSD 8.5mm wires, Gatorback belts etc. Either the PCM input has gone south or the PCM wants to see a specific mixture signal during this time. Watching an O2 simulator versus the real O2, I can't see the difference. This one is more complicated than most.
    Thanks for the thoughts. I'll try some more poking around.
  1. Setting up account
    By PWNED in forum PCM Tuning
    Last Post: 08-23-2008, 06:29 AM
  2. Getting 2001 GTP in 3 weeks
    By jacobmh27 in forum Introductions/Noob Questions
    Last Post: 03-25-2008, 10:21 AM
  3. Hood not setting right.
    By DanGTP in forum Visual/Body Modifications
    Last Post: 03-02-2008, 01:43 AM
  4. p0420 code on
    By fst in forum General Tech Discussion
    Last Post: 01-05-2008, 04:19 PM
