Thread: Rear O2 sensor connector location
Results 1 to 5 of 5
  1. #1 Rear O2 sensor connector location
    Nov 2011
    S Fla
    I'm yanking the engine and can't find the connector for the rear O2 sensor. Can anybody help me out?
    Thanks, Gas.
    Black 2000 GTP. Replaced plugs, wires, maf, IAC, tires, tie rod ends, and s/c oil. Lifetime alignment. No mods yet, just got it. Straightening everything out first. 128,xxx miles
  2. #2 Re: Rear O2 sensor connector location
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    there is a connection at the sensor itself. i would disconnect it there
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #3 Re: Rear O2 sensor connector location
    That's the only one I'm aware of. But...a motor pull shouldn't require the rear O2 to be disconnected. Only the front on a stock manifold.
  4. #4 Re: Rear O2 sensor connector location
    Nov 2011
    S Fla
    Geez, I should have realized both of those things. Kickin' myself for all the time I spent under there, SURE there was a connector and I just couldn't see it because everything is so tight under there. Time to get on with the bolts, then, I guess.
    Thanks for the answers. And for going easy on the new guy.
  5. #5 Re: Rear O2 sensor connector location
    If you search the word "eas y" without spaces and my screen name, you'll find a write up for pulling the engine/trans or whatever most of the time.
    I've put things in the best order and easiest ways that I know of, typically with the tools you need listed right there too.
    How's that for treating the new guy well?
  1. Maf sensor connector
    By ShadowSwept in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-10-2012, 06:38 PM
  2. O2 Sensor Location Help
    By 97GTzbban1 in forum General Tech Discussion
    Last Post: 03-20-2011, 08:30 PM
  3. sensor location
    By fritzie001 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2011, 11:41 PM
  4. ECT sensor location?
    By il0vellamas in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2010, 02:27 PM
