Thread: Dad gave us the OK, time to build up the 95 3800
Results 1 to 20 of 26
  1. #1 Dad gave us the OK, time to build up the 95 3800
    Donating Users 02GTINFERNO's Avatar
    Dec 2012
    Buffalo, NY
    We have a 1995 bonneville with 255+ on the dash. First of 3 3800s in the family and the first to go under the knife. Obviously alot is going to be done to it to make sure it will handle the build up but what all can you suggest we do to make this the ULTIMATE sleeper at the track? No stone will be left un turned and no avenue will not be ventured down. I'm talking gen 5 swap, trans build, mill work on the heads, pcm tune, everything. What all can you suggest we do? What all shouldn't we do?
    "INFERNO"
  2. #2 Re: Dad gave us the OK, time to build up the 95 3800
    Donating Users JLiss's Avatar
    Dec 2012
    Aurora, IL
    i can suggest one thing. Research.
    Power goals?
    I mean do you want it done fairly soon?
    Is money a issue?
    Power goals is the most thing i would look at.
  3. #3 Re: Dad gave us the OK, time to build up the 95 3800
    GTX Level Member HVACgtp's Avatar
    Oct 2012
    South Jersey
    Turbo? Lol
    2001 Silver GT; K&N Intake, 2.5in catback to flowmaster 40's, custom tune, led tails drag wheels and halos......SOLD
    2004 Silver GTP - its got some stuff http://www.grandprixforums.net/deja-vu-71112.html
  4. #4 Re: Dad gave us the OK, time to build up the 95 3800
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Ultimate sleeper? Turbo.
    GPONA #1 Cyber Bully
  5. #5 Re: Dad gave us the OK, time to build up the 95 3800
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    turbo, built trans, save for another trans.
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  6. #6 Re: Dad gave us the OK, time to build up the 95 3800
    Nov 2011
    NY
    Quote Originally Posted by HVACgtp View Post
    Turbo? Lol
    Lol, you Turbo guys!!!
    Haha, I vote for Twin Charged!!! The best of both worlds...
    (I like spending others money!)
    Quincy, Mass
    You'll spend just as much on an sc build as will on a turbo set up. But you'll be able to get my out of the turbo.
    No more GP 04 Impala SS Indy:
  8. #8 Re: Dad gave us the OK, time to build up the 95 3800
    Dec 2012
    Buffalo, NY
    So i think turbo would be easy with the crossover pipe where it is but how would i twin charge the car?
  9. #9 Re: Dad gave us the OK, time to build up the 95 3800
    SE Level Member Sevex's Avatar
    Aug 2012
    Utah
    twincharge is turboing the car then blowing into the supercharger hence "twin" or compounding boost, for simplicity reasons just go turbo if your going that far.
    04 CompG, 1.9 rr, 90# springs, modded SD headers, 42.5#.... intercooler/3.0 mps coming soon.
  10. #10 Re: Dad gave us the OK, time to build up the 95 3800
    It might be easier to tune if you switch it to obd2
  11. #11 Re: Dad gave us the OK, time to build up the 95 3800
    Dec 2012
    Buffalo, NY
    Its a late 95 so its already obd2, the port has no power so i have to get that working as well. Probably something simple like a fuse.
  12. #12 Re: Dad gave us the OK, time to build up the 95 3800
    Cig lighter fuse.
    Quincy, Mass
    To twincharge instead of using the blower block off plate you leave the rotor pack in. It's best to intercool the turbo and the supercharger on a twin setup.
    Bunnell, FL
    But how do you work the turbo blow thru past the super charger
    I'm a Sex Offender
  15. #15 Re: Dad gave us the OK, time to build up the 95 3800
    Dec 2012
    Buffalo, NY
    Quote Originally Posted by JLiss View Post
    Power goals?
    Is money a issue?
    Completely missed this post lol. For now the power goal is max without getting into the bottom end. The bottom end will eventually get taken care of but the car being as old as it is, i don't want to dump tons of money into the motor and not be able to do anything if the car splits in half lol. As far as time line it's not anything that has to be done right away, it's purely a project car so can sit for however long it needs to. Money isn't too much of an issue, my dad wants to know total cost or rough estimate but i told him it all depends on what we do. So i guess if we were to start buying things one at a time than that would be ok until we got everything going. The starting point for this project was this video on youtube:
    Obviously the amount of exhaust noise is from a cutout which is fine, but we want the noise and the go power to boot. Pulling up to the line at the local drag strip with a 95 bonneville and opening the cutout to see everyone go wtf? is what we are after. Straight line killer, no track day star or half dd half play toy, full on speed demon lol
    "INFERNO"
  16. #16 Re: Dad gave us the OK, time to build up the 95 3800
    Feb 2009
    flintnasty MI
    the 95 bonne's need to be flashed using tunercats, which will require socketing the ecu and running chip burner on it. Its sorta a pain but doable.
    The 60e scares me... They are pretty weak compared to a 65e and there is really no "built" option.
    Then turbo it.. the bottom end is good for around 600whp. You wont get half the way there on a blower setup.
  17. #17 Re: Dad gave us the OK, time to build up the 95 3800
    Dec 2012
    Buffalo, NY
    Who would be able to do the flashing on the ecu? Could i use the 65e instead or is that just for late model? The transmission in the car now is the factory trans from 95, never been rebuilt so i know it'll blow with any serious power put to it.
    "INFERNO"
  18. #18 Re: Dad gave us the OK, time to build up the 95 3800
    Feb 2009
    flintnasty MI
    if you went with a 65e you would have to swap the harness/ecu. You would have to buy a chip burner and socket the ecu to do any tuning work (not that you really need to do much).
  19. #19 Re: Dad gave us the OK, time to build up the 95 3800
    new britain, ct
    woulndt you just be able to swap PCM and wiring harness along with built 4t65e from a later model?
    as far as power goals. im always for a straight turbo setup and not for twincharging, at least not on an m90.
    07 Black GXP.
  20. #20 Re: Dad gave us the OK, time to build up the 95 3800
    I live here. TLSheff's Avatar
    What motor does this 95 Bonnie have in it? If its NA then you get the first of the Series II L36 motors. Prime for turbo, but I wouldn't bother with a GenV build on one that old. L32 swap into it and be done.
    If however its a SSEi, you don't get the goods. 96 was the first year for the Bonnies to get the SII L67, but 95 was stuck with the Series 1 L67 with the nasty M62 supercharger and multiple useless limited upgradable parts. Funny how they upgraded the NA motor, but kept the old "performance" one. Trust, still have my 94 sitting, there are very few mods without a complete motor swap. Again... best for a L32 swap and be done.
  1. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  2. Time for more POWAAA! (GEN V Build)
    By AmericanSoldier in forum General Tech Discussion
    Last Post: 11-03-2011, 08:07 PM
  3. if you could build your dream 3800 motor what would you use
    By kirkkarem1212 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2010, 12:30 PM
  4. Gave Her The Works, Spring Time
    By rocafella2032 in forum Visual/Body Modifications
    Last Post: 04-05-2010, 11:49 PM
  5. well I am starting a new audio build. This time it is sq.
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2008, 06:08 PM
