Thread: felpro or mls gaskets?
Results 1 to 8 of 8
  1. #1 felpro or mls gaskets?
    GT Level Member DaytonaGTP500's Avatar
    May 2012
    Iowa
    hey guys just looking for some opinions from y'all. I'm in the middle of building my car up throwing a s259 turbo on and blahh blahh, any ways I'm just trying to see what would be a better decision between the mls head gaskets with copper spray or the felpro ones(both with arp head studs). The goal is for 450-500whp on e85 and figuring around 15-20psi. I've herd of the felpro ones holding 700hp with arp studs but idk if anyone else has had any luck with high hp on felpro gaskets or if I should just figure out how to get the mls gaskets to seal and use them.
  2. #2 Re: felpro or mls gaskets?
    GTP Level Member AjL227's Avatar
    IL
    I have the Cometic MLS gaskets, and you won't feel an actual power difference.
    It is only extra work and more difficult to get them to seal.
    FelPro works fine.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  3. #3 Re: felpro or mls gaskets?
    May 2012
    Iowa
    But how much power can you make safely before blowing the felpro gaskets on ARP studs?
  4. #4 Re: felpro or mls gaskets?
    Feb 2009
    flintnasty MI
    600 might be an starting point for issues... I chunked mine around 700 but i was running way too much timing.
  5. #5 Re: felpro or mls gaskets?
    May 2012
    Iowa
    Do you have to do anything special with the install of the felpro gaskets our do you jus put them in like normal? And do you use Teflon tape on the studs or no? Cuz I've herd some say they do and others say that stuff don't belong around engines.
  6. #6 Re: felpro or mls gaskets?
    May 2008
    Schuyler, NE
    I would stay away from MLS. I've personally had good luck with Victor Reinz.
  7. #7 Re: felpro or mls gaskets?
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Had no problem with stocks myself
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  8. #8 Re: felpro or mls gaskets?
    May 2012
    Iowa
    Any one herd of the fel pro perma torque gaskets?
  1. LIM-FelPro gasket failure?
    By michael redmon in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-10-2015, 05:11 AM
  2. Felpro vs Thermoseal
    By JerzNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2012, 06:17 PM
  3. LIM gasket - felpro or GM
    By cavGTP in forum 04+ Specifics
    Last Post: 12-03-2010, 12:30 PM
  4. What are all these gaskets?
    By piperflyer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-07-2009, 02:22 AM
  5. felpro-premiums valve stem seals?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2008, 01:01 PM
