Thread: lifter replacement
Results 1 to 9 of 9
  1. #1 lifter replacement
    House springs missouri
    I'm about to replace lifters in a 98 GTP and I was wondering when I put it back together when I reinstall the rocker arms can I just tourque them down or do I have to rotate the motor and do it several times
  2. #2 Re: lifter replacement
    Omaha, NE
    The rocker bolts get torqued to 11ft lb.
  3. #3 Re: lifter replacement
    GTP Level Member AjL227's Avatar
    IL
    Hand tighten all rocker arm bolts.
    Turn the engine over as you go...
    Apply final torque to rocker arm bolts individually when they are not under "lift" from pushrod/lifter/cam lobe.
    You should be able to wiggle them around at that time, to confirm they are not applying pressure on the valve.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  4. #4 Re: lifter replacement
    Rocker bolt torque depends on which bolts you use. Stock bolts are TTY and should be replaced when you remove them. The spec on a stock bolt should be x ft lbs plus x degrees. Reusable bolts are torqued to 25lt lbs.
    On rotating the motor. I do. Obviously some of the valves are compressed and some aren't. Therefore...while you will typically end up with goood torque across all by just torquing, I have found one or two cases where rotoating the motor helped torque evenly.
    Plus a degree amount.
  6. #6 Re: lifter replacement
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  7. #7 Re: lifter replacement
    Jul 2012
    Clayton,NC
    x2 on what ajl227 and billboost37 said thats what I did when I installed my ls7 lifters and it hasnt blown up yet
  8. #8 Re: lifter replacement
    May 2008
    Schuyler, NE
    11 ft lbs. +90*...with a stock cam, I will just torque them all without turning the motor over an be done.
  9. #9 Re: lifter replacement
    Pennsylvania
    Hm, wish I knew that motor turning bit before now. Hope the +90* turn covered those bases for me.
  1. Lifter and LIM gasket replacement
    By plasmeh in forum General Tech Discussion
    Last Post: 05-09-2011, 10:11 PM
  2. Advice on lifter replacement
    By goldgp in forum General Tech Discussion
    Last Post: 02-12-2011, 08:51 PM
  3. Engine ticking still, After lifter replacement.
    By 02grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2011, 01:58 PM
  4. Lifter replacement
    By kfish in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-17-2009, 05:35 PM
  5. Bad Lifter?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2009, 10:03 PM
