Thread: Make your own Fuel Rails?
Results 1 to 7 of 7
  1. #1 Make your own Fuel Rails?
    Nov 2011
    NY
    Just wondering... Who has made their own? Is it worth it... I've done some research, but want to hear it from those who have done it, good or bad?
    Thanks for your input...
  2. #2 Re: Make your own Fuel Rails?
    GT Level Member 88formula's Avatar
    Oct 2012
    West Branch, MI
    I am pretty sure fuel rails have no benefit other than a cleaner look...
    Bunnell, FL
    It's more than just looks
    Its also about clearing the innercooler
    I'm a Sex Offender
  4. #4 Re: Make your own Fuel Rails?
    HUDSON
    I have made my own fuel rails in the past, not for 3800's, but for other F.I. projects, only becuase "off shelf" or "factory" rails were not available. Fuel rails may sound simple, unless you have a strong fabrication background, I would not recomend it, especially if they are available already for purchase. You are not going to save money making your own, if you build them properly.
    The Boss Iceman6669's Avatar
    Jun 2011
    Quote Originally Posted by 88formula View Post
    I have heard that the ones that take the feed line around the blower and not over the blower reduce "hot spots" in the fuel rail.
    2011 F-150 Yote powered
  6. #6 Re: Make your own Fuel Rails?
    Quote Originally Posted by Iceman6669 View Post
    And then there are those that throw logs on and KR disappears.
  7. #7 Re: Make your own Fuel Rails?
    Nov 2011
    NY
    Fabrication is not a problem, drill press and tapping, etc. no worries there.
    I was more interested in knowing how much of a ***** it might be, leaks, finding the right parts, etc., problems and pitfalls that anyone had.
    Interesting that I didn't even think of the heat (s/c) issue, lol...
    Wonder if a fuel line I/C would offset some of the heated s/c air?
    hehe...
  1. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  2. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
