I am under the impression that to safely run an XP cam on "stock" heads you need modified retainers, and Vitan valve stem seals. Is this correct?
Also I ordered a complete engine gasket set from Fel-pro and it came with some "Premium valve stem seals"... I have done as much reading about this subject as I could find, and am still unclear if I have the correct valve stem seals or not?
