Thread: So I just picked up a set of L32 heads..... Now what?
Results 1 to 5 of 5
  1. #1 So I just picked up a set of L32 heads..... Now what?
    GTX Level Member crbquist's Avatar
    Massachusetts
    As the title reads, I just scored a good used set of L32 heads. They are off an 04 GTP motor and had 30-ish thousand miles on them when removed. They appear to be in great shape on the outside... Now, I want to get them p&p, valve job, etc. from a local shop but am not sure where to start. Should I just bring them to a place and get their opinion? I have an s1x cam and am keeping it, so I imagine all I would need is a mild p&p since my cam is pretty small. What about valves? Should I keep the stock L32 ones or go bigger like Manley or something alike? How about the bowls? What else? Basically just looking for a bit more power. The heads will be installed with a full size IC over the winter. So far I am thinking retain the stock valves, mild p&p of intake and exhaust, 105 springs, new seals, and titanium retainers. What do you head guys think??
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
    Ohio
    Gasket match the intake. Open up the exhaust ports more and keep a nice "D" shape on them. Then polish the bowls.
    That's all you need.
    Massachusetts
    Quote Originally Posted by 99PGPGT View Post
    I heard that gasket matching the intake is not really necessary as the motor is forced induction.
    Ohio
    Just gasket matching isn't hurting anything. A full port job is too much.
    Just gasket match and smooth the casting.
    And then port the exhaust alittle and smooth it out as well.
    Massachusetts
    Ok, I should probably have the LIM gasket matched as well right?
  1. Just Picked up a 00 GTP
    By Adrenalin3 in forum Introductions/Noob Questions
    Last Post: 01-24-2012, 11:00 AM
  2. Just picked up another GP
    By Dobbs122 in forum General Tech Discussion
    Last Post: 08-19-2011, 04:58 PM
  3. picked up new car/got ?'s
    By nyls1346 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2011, 09:35 AM
  4. Look at what I picked up!
    By 04BlackComp_G in forum General Tech Discussion
    Last Post: 09-01-2010, 09:27 AM
  5. Just Picked up my new GP
    By Luda in forum Introductions/Noob Questions
    Last Post: 05-30-2009, 07:57 AM
