Thread: ZZP Oil Pans
Results 1 to 11 of 11
  1. #1 ZZP Oil Pans
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Are the oil pans ZZP sell stock Dorman oil pans? And why do they state that a magnetic drain plug would not work with theirs?
    ZZPerformance - Oil Pan #ZZ-OILPAN-38
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: ZZP Oil Pans
    GT Level Member 88formula's Avatar
    Oct 2012
    West Branch, MI
    The thread pitch/size is different from the plug they sell, I cannot answer the other part of your question though.
  3. #3 Re: ZZP Oil Pans
    M12-1.75 is the stock replacement IIRC.
  4. #4 Re: ZZP Oil Pans
    Bowie, MD
    Ok. The reason i asked was because i wanted to replace my oil pan on my motor....but still debating if i should. It just has a small ding on the bottom right but everything else is still good. I was thinking i should just clean everything up and repaint it and change the gasket. Any suggestions?
  5. #5 Re: ZZP Oil Pans
    Oct 2012
    West Branch, MI
    Mine is smashed in on the bottom, I also was planning on replacing it, but then decided who cares. No one will ever see it, and it doesn't leak.
  6. #6 Re: ZZP Oil Pans
    Bowie, MD
    Thats true lol. Ill just clean it up and repaint it black and change the pan gasket.
  7. #7 Re: ZZP Oil Pans
    I have taken a 4x4 or other block of wood and pounded a pan or three out while they were off the engine. It's all good.
    Yup mine is worse then that. No leaks so I won't bother going through the hassle of replacing it.
    04 Comp G.
    Bowie, MD
    Cool thanks guys. Any special procedures when installing the new pan gasket?
    Sent from my SGH-T989 using Tapatalk 2
  10. #10 Re: ZZP Oil Pans
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    I dont think it requires RTV but i like putting a even amount of Black RTV on the gasket itself just make sure you clean the pan and block where the pan bolts up to well, clean all the oil and dirt of it just did mine last week.
  11. #11 Re: ZZP Oil Pans
    And did your rear engine cover gasket start seeping again? It will
