Thread: Need some help (Balancer removal/Engine stand)
Results 1 to 20 of 39
  1. #1 Need some help (Balancer removal/Engine stand)
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Having a little trouble removing this harmonic bolt from the engine on my engine stand. I have 2 vice grips on the flex plate flywheels that catches on to the End of the engine to stop the flex plate and balancer from spinning.
    I also have a breaker bar but when I turn and put force on the breaker bar....I'm afraid the engine will break from the engine stand and the engine will fall if I put too much force I to it. Any advice and help would be greatly appreciated.
    Sent from my SGH-T989 using Tapatalk 2
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: Need some help (Balancer removal/Engine stand)
    Put some muscle in it. It shouldn't break off the stand.
  3. #3 Re: Need some help (Balancer removal/Engine stand)
    Mercer, Pa
    I picked mine up off the ground a little with the engine hoist.
  4. #4 Re: Need some help (Balancer removal/Engine stand)
    Mercer, Pa
    Key word SHOULDN'T
    And should come off rather easy this time around since you already had it off once before.
    04 Comp G.
  6. #6 Re: Need some help (Balancer removal/Engine stand)
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Brace the front of the motor so it not flexing when your trying to break the bolts loose.
  7. #7 Re: Need some help (Balancer removal/Engine stand)
    Different motor
    Didn't know that ! Do you still have the engine hoist available?
    04 Comp G.
    Bowie, MD
    Quote Originally Posted by sseilmnop View Post
    I was thinking of actually doing that but didn't try
    Bowie, MD
    This is a whole different block. This one is going in my girlfriends car.
    Bowie, MD
    Ok so tommorow ill try and hold or support the front end with either the engine hoist or something with equivalent height and see how that goes.
    I also wanna paint the block RED!!!! Would caliper paint work well? I have about an entire can left over front when I did my calipers summer of last year.
    I never noticed any difference between caliper paint and engine enamel I've used both on various things when I have a can left over.
    04 Comp G.
    Bowie, MD
    Oh ok. Caliper paint seemed to last in my calipers for a while untill they started chipping which I think was due to the road and rocks.
  14. #14 Re: Need some help (Balancer removal/Engine stand)
    GT Level Member 88formula's Avatar
    Oct 2012
    West Branch, MI
    I wish I could have told you to remove this bolt sooner! That was the worst part of my tear down... Now if I had a picture of what I did it would be worth a thousand words. As you said, when you torque it the engine stand wants to tip over, and believe me it will take a ton of force to break the bolt loose! I ghetto rigged the stand with 2x4's braced underneath the cradle that was right near the engine stand, then stood on the 2x4's and gave it all I had. Dont know if this makes any sense, but it is my best description of what I went through to get that bolt out! LOL
  15. #15 Re: Need some help (Balancer removal/Engine stand)
    Oct 2012
    West Branch, MI
    Quote Originally Posted by GOTIT4CHEAP16 View Post
    My heads and block also are going to be red (chevrolet Orange-red-DE1607) LIM, blower, etc will be aluminum colored paint...pulleys, fuel rails, and various other things, along with maybe my headers, will be painted black.
    Bowie, MD
    Quote Originally Posted by 88formula View Post
    Wow sounds like this is gonna be a ***** lol. It was woo easy to get off the one on my car. I guess I will see how things go tommorow after I put some supports Under the engine. I'm a relatively Strong 6'3 250lbs guy and workout/bench alot so ill put my all into it lol.
  17. #17 Re: Need some help (Balancer removal/Engine stand)
    Oct 2012
    West Branch, MI
    I had to give it good heaves and make funny noises to get it to snap, im also similar build to yourself. I could hold myself off the ground on the pry bar lol
    Bowie, MD
    Damn lol
  19. #19 Re: Need some help (Balancer removal/Engine stand)
    im also a large guy, and i still use a large pipe to break bolts like that. why kill yourself even if you can bust it free.
    work smarter, not harder lol
  20. #20 Re: Need some help (Balancer removal/Engine stand)
    Impact gun.
  1. Harmonic Balancer Bolt Removal
    By h0wl0ngcanitbe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-29-2012, 09:35 AM
  2. harmonic balancer removal
    By ericg1181 in forum General Tech Discussion
    Last Post: 08-05-2012, 12:38 PM
  3. Engine stand run...
    By tonka329 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2012, 03:45 PM
  4. Borrow a engine stand
    By GAFF in forum Midwest
    Last Post: 06-06-2010, 07:31 AM
