Thread: waaaaaarm!
Results 1 to 11 of 11
  1. #1 waaaaaarm!
    SE Level Member Elrodd384's Avatar
    Mar 2012
    Fort Campbell, KY
    Hey guys, just an oddball question. So I've recently had my cooling system flushed and replaced with dexcool, full tuneup, removed hood liner, and replaced the airbox with an open cone. Car runs cool and heats up quick, steady at 194°. My question is that the engine SMELLS like it's running hot and the engine bay is super heated. I know my cart is done for and I'm guessing this is the cause, am I correct?
  2. #2 Re: waaaaaarm!
    Dec 2012
    Zeeland, Michigan
    It's shouldn't be look for any leaks in the system, or go back to where you had it done. If their not bastards they'll do it for you again.
  3. #3 Re: waaaaaarm!
    St. Louis
    If they flushed and filled, they should have bled the cooling system as well. May not have been done. Get the motor up to temp and wait for the thermostat to open up, then crack open the bleed screw on top of the thermostat housing and wait for a steady stream of coolant. If it spits and sputters out first then that would be air in the system.
    Although, with a 190* thermostat and fans that come on around 212 that sounds about right for stock temps.
  4. #4 Re: waaaaaarm!
    Mar 2012
    Fort Campbell, KY
    I meant cat, not cart. My cat is toast and getting cut out. Sometimes I get and evap code
  5. #5 Re: waaaaaarm!
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Love the name of your thread, love Ace Ventura! xD
  6. #6 Re: waaaaaarm!
    Uh what?
  7. #7 Re: waaaaaarm!
    Mar 2012
    Fort Campbell, KY
    Car smells like hot oil I guess would describe it
  8. #8 Re: waaaaaarm!
    Pennsylvania
    If it "smells like hot oil," I'd assume that, barring fluids dropped outside engine, there's oil dripping from the typically-leaky valve cover gaskets on to the exhaust manifolds.
  9. #9 Re: waaaaaarm!
    Mar 2012
    Fort Campbell, KY
    Lmao on the pic. I guess hot oil isn't the best description, it just smells hot when I pop the hood and the center console is warm to the touch. Like my cat is a million degrees
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Heat rises up into the wngine bay from the cat and your hood traps the heat in so that's going to be a lot of your heat and its prolly warming up the thick layer of oil that's accumulated over the years from leaky valve covers
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by Utter99 View Post
    Sounds like ya due a trip to a car wash with a can of engine degreaser and pressure washer
    Sent from my pager using Morse code. ... .. ... ....
