Thread: ~7 degrees of KR on 3.5" pulley, please Advise
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Check and make sure your trans dipstick isn't hitting the header and that your motor mounts are good and not causing the headers to hit the firewall or anything like that.
    The motor mounts are great, solid rubber. The trans dipstick is a possibility, but I haven't otherwise modified my setup since going to the smaller modular pulley, so I figure that would isolate a variable like that.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #22 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    damn man that sucks your getting KR, you dont have a tuned pcm at all? that is likely your problem. at the least get a canned tune. overkill zzp or wbodystore. overkill is very hard to get ahold of. i have zzp. been good for me
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  3. #23 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Nov 2011
    NY
    Quote Originally Posted by GTP131 View Post
    I was trying to avoid spending money on tuning, but it appears that I might have no other choice. Please, share your thoughts and ideas.
    What makes you think you wouldn't need to tune in the pulley drop? Obviously, you're knowledgeable to a point but are either intentionally or unintentionally ignoring what NEEDS to be done.
    Scan & tune @ each pulley drop, dialing in the settings until just right, then drop again, or add mods to address the knock. You are looking to skate the entire monopoly board and win the game all at once. Personally I don't think it's a good idea. Basically amounts to Russian Roulette with your engine.
    Cheap/Fast/Reliable
    You can only have two of these...
    Trying for 3 = Fail!!!
    Just my $.02
  4. #24 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Ontario
    Whenever you increase power, flow, fuelling, etc, you HAVE to tune for it.
  5. #25 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    damn i had a 3.35 pulley on headers fwi and p&p blower with tr6 plugs and didnt get that much kr untuned i had a 0 in first and then about 3kr in 2nd that a ass kicker i did the zzp 1.0 tune that i got used for cheap works good maybe get 1 kr when it 29 deg out at top end thats about it
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  6. #26 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Knoxville, TN
    Alright, I'll go ahead and look into tuning. I was thinking that with the right mods, the flow would balance the increase in boost, but apparently it wasn't enough. A few members on here suggested that I go ahead and try going without a tune first, so I gave it a shot.
    Also, though some of you like the ZZP tune, I heard bad things about it "back in the day" and I think I'll either get tuning software or a DHP PCM. I don't really trust a company that tells people they can run a 3.5" pulley stock when obviously a 3.5" is too much for my car with headers.
  7. #27 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Troy OH
    all in the tune. keep in mind, air temps are getting colder quicker this time of year and gas stations are switching to winter blend gas. a stock pcm isn't going to be able to compensate right with the added air flow from your mods. probably just going lean under load leading to the kr you're seeing
  8. #28 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Knoxville, TN
    Quote Originally Posted by Poil336 View Post
    This was kind of what I was thinking, even though I'm new to the tuning scene. I figure, with more than enough flow for a 3.4, let alone a 3.5, my AFR should probably be my main concern. My only worry is that, in the process of tuning for a 3.5, I'll have to cut too much timing, or have a silly rich AFR.
    Is there a problem to having AFR that's a bit on the high side just for WOT and "normal" AFR for the rest of my driving? I'm one to only floor it a few times a week, otherwise I drive quite sanely.
  9. #29 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Getting a solid WB tune in that thing should kill all that KR, even on a 3.5".
    Quote Originally Posted by 00grandprixgtp View Post
    And the AFR was probably 10:1.
    Yay, canned tunes.
  10. #30 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    I have 10.5:1 afr right now I'm going to get a real tune eventually.
  11. #31 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Yay, fuel washing the cylinders.
    bam.
  12. #32 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    10.5 wont wash the cylinders.
    Try sub 10's and then your talking possible bad news.
