Thread: Help with vacuum T's
Results 1 to 7 of 7
  1. #1 Help with vacuum T's
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    Hey guys my vacuum T under my snout got a big tear in it. Took it out and the line also was broke off in 1 end. Went to all the auto stores and they dont sell rubber T's like I need. Where can I get a T and maybe the line as well? Thanks, cars out of comission until i get one..
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  2. #2 Re: Help with vacuum T's
    like this.
  3. #3 Re: Help with vacuum T's
    i looked around, the rubber T's are not to be found at a parts store, just plastic T's and vac tubing. get the small ones.
  4. #4 Re: Help with vacuum T's
    Dec 2008
    Cedar Rapids, IA
    under the snout scotty where does the rear line lead to?
    the only one you cannot see in the pic
  5. #5 Re: Help with vacuum T's
    it leads to the map sensor, i left that line stock, stuck the stock tube into vac line to the T.
    the vac line leads under the sensor, you can pop that one off and run a new vac line to it as well if you need to.
  6. #6 Re: Help with vacuum T's
    hers a diagram
  7. #7 Re: Help with vacuum T's
    Texas
    They make those plastic t's in different sizes. Run a vac line from the LIM port to a plastic T then connect your two other lines.
    85 Corvette
    01 TA
    03 Z06
  1. Need Some Vacuum Help
    By gtpeddie in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2012, 11:33 AM
  2. vacuum?
    By stonecold0469 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2012, 05:29 AM
  3. GTP vacuum TEE's
    By mobiletec in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2012, 08:40 PM
  4. vacuum leak?
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2010, 01:27 PM
  5. vacuum
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 10-05-2009, 09:09 PM
