Thread: How many times can a crank bolt be re used?
Results 1 to 6 of 6
  1. #1 How many times can a crank bolt be re used?
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    I installed my vs cam about 1 month ago and replaced everything........Can i re use the same crank bolt again? How many times can i re use it?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: How many times can a crank bolt be re used?
    Just loctite it.
    Reuse it forevah
  3. #3 Re: How many times can a crank bolt be re used?
    Quincy, Mass
    im on my 5th or 6th time, dont remember if i even bothered to use locktite last time
    No more GP 04 Impala SS Indy:
  4. #4 Re: How many times can a crank bolt be re used?
    Bowie, MD
    Ok cool no point in wasting money on a new one then. cool. Thanks guys.
  5. #5 Re: How many times can a crank bolt be re used?
    Bowie, MD
    How about the cam bolt?
  6. #6 Re: How many times can a crank bolt be re used?
    I've reused both so many times I lost count. And I never loctited. I airgunned those mofo's.
  1. 24 mm bolt on crank?
    By legend in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2012, 05:01 AM
  2. Crank Bolt Will Not Come off
    By BoilerTom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2012, 08:03 AM
  3. problems removing crank bolt from hub
    By BonesSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2010, 07:50 PM
  4. HELP! Can't remove crank pulley bolt!!!
    By Billy Low in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:06 PM
  5. How to hold Harmonic Balancer Still to Remove Crank Bolt?
    By pontiackid in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 09:00 PM
