Thread: 99 gtp misfire #1 under load /in boost Heelp!!
Results 1 to 13 of 13
  1. #1 99 gtp misfire #1 under load /in boost Heelp!!
    Feb 2009
    North Adams, Ma
    i have a 99 gtp getting a misfire under load and/or into boost... only #1 idle is fine seems to have good comperssion changed all plugs 104s wires acdelco swapped pcm, icm, coils, injector any ideas?
    thanks
  2. #2 Re: 99 gtp misfire #1 under load /in boost Heelp!!
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    So no matter what you switch (plug, injector, coil) this miss remains in CYL #1? Is everything else operating normally? Coolant remains full, oil is good?
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  3. #3 Re: 99 gtp misfire #1 under load /in boost Heelp!!
    Feb 2009
    North Adams, Ma
    yes everything appears to be good......no overheating or milkshake.... does this sound like a chipped piston? my thought was the compression would show that? exhaust doesnt appear to be obstructed... the thing that i dont understand is i was able to get a p0300 cleared and havent gotten that again...
  4. #4 Re: 99 gtp misfire #1 under load /in boost Heelp!!
    do a compression test
  5. #5 Re: 99 gtp misfire #1 under load /in boost Heelp!!
    St. Louis
    You running at least 91 octane?
  6. #6 Re: 99 gtp misfire #1 under load /in boost Heelp!!
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Had this exact same problem, For me it was a vacuum leak. Check all your vacuum lines (literally take off the couplers) and check them for cracks... a spray test didn't show any issues with mine but when I pulled the vacuum line to the throttle body, it was split on the bottom.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  7. #7 Re: 99 gtp misfire #1 under load /in boost Heelp!!
    Feb 2009
    North Adams, Ma
    93 octane, vac at map senser is normal and boost gauge read the same but will double check all vac lines for leaks
    Thanks
  8. #8 Re: 99 gtp misfire #1 under load /in boost Heelp!!
    Feb 2009
    North Adams, Ma
    ok ive had no luck with anything replaced vac lines with "t"s lower intake manifold gaskets... still no change will throw a p0300 has 120 psi compression..... scratching my head?
    any other advice?
    thanks
  9. #9 Re: 99 gtp misfire #1 under load /in boost Heelp!!
    What are your other cylinders compression? You can't just check one and call it good.
  10. #10 Re: 99 gtp misfire #1 under load /in boost Heelp!!
    Feb 2009
    North Adams, Ma
    well i understand that but why would my aeroforce show a misfire in cylinder #1 and the compression in another cylinder cause it to misfire there? the p0300 code is a random misfire and only misses on the #1 i checked #3 it was 125 with both plugs out...
    Check the compression in all 6 cylinders and report the #'s and compare them to verify I believe if they're are within around 10 or less difference between them. Just checking one cylinder your going to have a hard time finding a number to compare it with.
    04 Comp G.
  12. #12 Re: 99 gtp misfire #1 under load /in boost Heelp!!
    tennessee
    mods to warrant 104's??? spark might not be hot enough to fire that cylinder if there arent any substantial modifications increasing cylinder temps, and if possibly and i mean its a stretch but maybe compression on cyl1 is just low enough coupled with the lowered heat of the 104's causing cyl1 to miss, but im gonna stick with the first and get some autolite copper 605's... also nasty vacuum leaks can occur between sc and lim and sometimes even changing the sc gasket wont neccessarily fix the problem... what i did was place some GRAY rtv on both sides of the sc gasket around the intake port and that fixed it... best way to fix tht one is to have the intake manifold resurfaced tho... just some suggestions good luck
  13. #13 Re: 99 gtp misfire #1 under load /in boost Heelp!!
    Feb 2009
    North Adams, Ma
    sorry it been a while since i have updated... got this thing figured out it was a combination of things...bad supercharger gasket and a bad new spark plug...
    thanks for the help!
  1. cutting out under load and boost!!
    By Blowblackorgetback in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2012, 10:08 AM
  2. #4 misfire during boost, also bank 1 lean
    By petebjork in forum Introductions/Noob Questions
    Last Post: 06-01-2012, 11:44 PM
  3. Misfire when car warms up and no boost
    By jjuver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2012, 06:26 AM
  4. Misfire when getting boost on 99 gtp help!!
    By Machzzzz1 in forum General Tech Discussion
    Last Post: 11-21-2010, 10:20 PM
  5. Horrible misfire under heavy load: P0300, and P0171
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2010, 06:28 PM
