Thread: Weird WOT experience
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 Weird WOT experience
    GTP Level Member Ultra440's Avatar
    Ohio
    I floored it from a red light and kept my foot to the floor. I felt a strange shudder right before the gear shift. Kinda felt like power cut out, back in, back out and back in again over the course of about 2 seconds. Thoughts?
    2003 Park Avenue Ultra- 15% tint, 12" audiobahns, dynamatted trunk and doors, tinted tails, LEDs all around, HID headlights, f body brakes, sd headers, 3.5 pulley and supporting mods
    http://www.grandprixforums.net/my-03...tml#post824292
  2. #2 Re: Weird WOT experience
    Maybe the rev limiter, torque management, misfires or the trans hates you.
    Its too hard to say what happened. Now if you had a log/file of this happening it would be easier to pinpoint it.
    Ohio
    Or fuel pressure is dropping off.
  4. #4 Re: Weird WOT experience
    If it was 1st gear, that wouldnt happen unless his pump is weak.
    Fuel pressure drop off from what I remembered was 10-12+ seconds of WOT.
    Ohio
    That's what I'm saying. The pump could be dieing. Mine would shudder right before it shifted into second.
    Ohio
    I wouldn't doubt the pump... I can do it again tomorrow with the scanner hooked up, what am I lookin for?
    Ohio
    Fuel pressure.. So go get a fuel pressure tester/gauge and measure it
  8. #8 Re: Weird WOT experience
    I'd monitor
    Fuel pressure...which is manual
    Timing commanded
    Actual timing delivered
    Knock Retard
    Calculated torque (trans)
    MAF
    TPS
    RPM
    B1 S1 O2
    Speed
    I'm thinking it's torque management or KR off the cuff. Might be fuel. Tough to say for sure.
    Ohio
    I've scanned pretty regularly and my KR issue is at low rpm tip in... Non existent at WOT. I saw 2* at third gear shift one time, months back.
    Fuel pressure gauge... Something like this work? http://www.harborfreight.com/fuel-in...ter-92699.html
  10. #10 Re: Weird WOT experience
    That should do it
    Ohio
    Now, torque management. How would I know if this is what was causing it? And if it is torque mgmt, it's nothing to stress about then? It felt pretty not normal
  12. #12 Re: Weird WOT experience
    Well..TM would induce KR to remove timing and back you down. TM kicks in with various torque levels, abusive behavior etc etc. TM is usually induced at shift points to keep you from full power shifting.
    Ohio
    Cool. Informative. Thanks bill
  14. #14 Re: Weird WOT experience
    GT Level Member papaspanky's Avatar
    Jul 2010
    new england
    what bout traction control?
    81 T/A pure Pontiac 350,700r4 3.23's coming soon pure Pontiac 462 06 gt wizaird,XS power Headers,zzp ss ic,overkill tune 180 stat autolite 104's, 3.6 pulley.Special Edition HORNY DRIVER mod.
  15. #15 Re: Weird WOT experience
    It's a Park Ave
    Ohio
    I've got traction control and it was on actually
  17. #17 Re: Weird WOT experience
    TM pulls timing without inducing KR.
    If KR does present itself, its a byproduct.
    Ohio
    So this happened again and worse. I pulled next to a gxp at a red light and floored it. Not exactly sure what happened when, just know that something is wrong. I think I wa doing about 45 when it started. Its a bad shudder/vibration and performance loss. Its been running pretty good under normal driving conditions. I'm going to pull the front three plugs after the engine cools an then the back three tomorrow afternoon. Just to rule out piston damage. I'm also using oil with no visible leaks.
  19. #19 Re: Weird WOT experience
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    My car did this everytime at the top of 2nd gear.
    It would shutter with powerloss/cutoff and then come back.
    Thats because i was seeing 7* KR.
    That could be your issue also, My car is stock BTW.
    Ohio
    Okay so does this tell anyone anything? This is a freeze frame of when the symptoms occurred. Not the first grey line, but the second green one where the misfires occur. Looks like misfires and kr at gear shift... Does that mean engine, tranny or both?
    Will tranny slips set off the knock sensors?
  1. Joe Rogan Experience
    By OmegaRed in forum Off Topic Discussion
    Last Post: 08-25-2011, 03:25 PM
  2. s2x cam, need opinions and experience
    By Poil336 in forum General Tech Discussion
    Last Post: 09-01-2010, 12:44 PM
  3. Experience?
    By CeeCeeRider in forum General Tech Discussion
    Last Post: 01-12-2010, 06:21 AM
  4. Great Experience
    By jshifti33 in forum Off Topic Discussion
    Last Post: 07-30-2009, 08:06 AM
  5. Anyone have experience with this DP?
    By the1euge in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2008, 08:25 PM
