Thread: Cold start problems
Results 1 to 4 of 4
  1. #1 Cold start problems
    Jul 2012
    Palmer, Ma
    I know I'm still new around here but ive searched this and cant seem to find any info on here about this. I have a 99 gtp and now that its getting a little cooler out after the car has been sitting while im at work or overnight in the garage when I start it, it stalls out right away. It takes about 3 tries to finally stay running I have to hold the gas down and bring the rpms up to about 3000 for about a minute then it will hold an idle. I have cleaned the mass air and the IAC valve. Once the car is warm its not an issue. I can shut it of and start it back up an hour later with no issue. I'm hoping sombody could point me in a direction of what else to check. Thanks in advance. Joe
  2. #2 Re: Cold start problems
    St. Louis
    Might be time to remove the throttle body and clean it good inside and out. The back of the butterfly valve (part of it facing the intake) usually gets carboned up pretty good. Then replace the IAC. Cleaning them is usually just a bandaid if they aren't working correctly.
  3. #3 Re: Cold start problems
    Jul 2012
    Palmer, Ma
    I will try that tonite and hopefully I will have better luck tomorrow morning. Thanks
  4. #4 Re: Cold start problems
    Jul 2012
    Palmer, Ma
    Took the throttle body off and cleaned it. It was nasty. Did replace the IAC and the car started right up this morning, no stalling and idles smoother than ever. Thank you.
  1. e85 cold start
    By gtpsleeper in forum PCM Tuning
    Last Post: 01-03-2012, 12:35 PM
  2. Stumble on cold start
    By RotyP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2011, 10:32 PM
  3. ticking at cold start...
    By twol8uluz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-24-2011, 10:01 AM
  4. Hard Start When Cold
    By TheRoadWarrior in forum General Tech Discussion
    Last Post: 04-28-2011, 10:36 PM
  5. cold start smoke
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 09:42 PM
