Thread: Swapping Engine
Results 1 to 10 of 10
  1. #1 Swapping Engine
    Oct 2008
    Texas
    HI friends I am in the process of removing my 3.8 supercharged engine need some advice on how to manage and remove it THX
  2. #2 Re: Swapping Engine
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    Not sure of what specifics you need really. How mechanically inclined are you?
    2006 Grand Prix GXP
  3. #3 Re: Swapping Engine
    Oct 2008
    Texas
    i have never swapped an engine before and i just bought my gtp and it blew up on me and i have to take out the motor and i need step by step instruction on how to remove engine
  4. #4 Re: Swapping Engine
    Banned
    Wichita Falls, Texas
    Where are you located?
  5. #5 Re: Swapping Engine
    Oct 2008
    Texas
    I live in san antonio
  6. #6 Re: Swapping Engine
    Banned
    Quote Originally Posted by Redgtp1999 View Post
    Oh yeah? Thats a cool place, I was just there a few months ago. What part of the city do you live in?
  7. #7 Re: Swapping Engine
    Oct 2008
    Texas
    the reason i want to swap engines is cause it's throwing out blue and white smoke really bad i need suggestion on what to do fix it or put another motor ????
  8. #8 Re: Swapping Engine
    Banned
    What kind of mods do you currently have? Need more information to better answer your question since something you have installed, or had installed for you might of caused a failure.
  9. #9 Re: Swapping Engine
    Oct 2008
    Texas
    No MODS stocked just want to know if there are any websites, pics, or videos i can use as reference if not then iam going to have to do it myself and get lucky! wish me luck!
  10. #10 Re: Swapping Engine
    Jul 2008
    New York
    I am not aware of an engine removal video. I could be wrong but i sence that you are highly underestimating the difficulty in removing an engine. Keep in mind that if you plan on a swap you will not only have to remove the engine but the transmission as well. It is more then a weekend job even for an experienced mechanic.
    You should exhaust your options before you attempt to do a swap.
    Answer these things.
    1) Does the vehicle run at all? if so to what extent. [explain a bit]
    2) You said the car is emitting smoke, where is the smoke coming from? The engine bay, the exhaust? If so where exactly on the exhaust or engine.
    3) Do you hear any noises feel any vibrations?
    4) How many miles are on the vehicle? On the engine?
    5) What year is it? Is it possibly under warranty? [your name alludes its a 99 and probably not under warranty]
    2006 Grand Prix GXP
  1. Which engine
    By Pontiacman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2008, 04:15 PM
  2. Engine Rpm
    By 04 GTP COMP G in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2008, 12:36 PM
  3. Detop swapping the GS???
    By Andrew_99GTP in forum Off Topic Discussion
    Last Post: 05-26-2008, 12:23 AM
  4. Engine???
    By duane9586 in forum General Tech Discussion
    Last Post: 05-10-2008, 09:46 AM
  5. Thinking of swapping out the stock headunit....
    By Y2KGTP in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2008, 11:08 PM
