Thread: Ported TB Issue
Results 1 to 8 of 8
  1. #1 Ported TB Issue
    Donating Users Uno99's Avatar
    Appleton, Wi
    I went ahead and purchased the ZZP PTB. Well I followed the instructions and went out for a ride and all went well. A few hours later I jumped in my car to bring a movie back and it starts "wiggin out" and died on me. Now the car will only idle nice when the engine is cool and once it warms up after about a min the idle starts to roll and it get so bad she dies. I disconected the battery and waited to try to reset the PCM several time. I tried it screen and de-screened. I also played with the bump stop screw that controls the TB blade position. I put the stocker back on it it purrs like a kitten. What gives?? Maybe the ZZP 1.0 Tune?? Is it tuned for a stock TB?? mods are below.
    3"DP w/ high flow cat
    3" exhaust w/ Flo Pro mufflers
    Intense S1X cam
    Roll Master single roller timing chain
    Balance shaft disabled
    Compam 105lbs Valve Springs
    CompCam Titanium Retainers
    Intense MPS 3.2" pulley
    Ported Exhaust manifolds
    Tranney Cooler/ZZP Shift Kit
    ZZP 1.0 PCM Tune
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  2. #2 Re: Ported TB Issue
    You might have a leak somewhere...either that or a bad sensor? idk thats odd...go figure...its ZZP too, thats problem #1
  3. #3 Re: Ported TB Issue
    Hoffman/Schaumburg, IL
    ^^This is exactly how my bad maf showed up, one day it just started running crappy when warm..... cold engine ran fine, when moving it was ok, but idle or light - medium throttle was horrible, sometimes stalling.........
    And unplugging it didn't help, If you can find a local with a good working MAF, that is the best way to test
  4. #4 Re: Ported TB Issue
    Barksdale AFB, LA
    Yep, could've gotten a bad MAF from ZZP. Or, the IAC could be bad. I'd say swap over all the electronics from your old one (I did that anyway, so I knew the history).
    2009 Subaru Impreza WRX STI
  5. #5 Re: Ported TB Issue
    Appleton, Wi
    well I emailed them again with no luck
  6. #6 Re: Ported TB Issue
    Appleton, Wi
    OK i got a repsonse from ZZP today and this is what they said. Keep in mind I copied and pasted my 1st post in this thread directly in the email I sent them.
    Quote from ZZP Customer Service Below
    "The 1.0 PCM is not meant for a car with a cam. Is it our basic 1.0 flash?"
    OK that tells me why there is a problem but what is the solution? It would have been nice for them to offer me a few option.
  7. #7 Re: Ported TB Issue
    Appleton, Wi
    Alright things are looking up now. The Owner Zoomer has contacted me and we have a plan for action. I have to send in my pcm and stage I TB. They will be reflashing my PCM and sending me a stage II for a bit more cash.
  8. #8 Re: Ported TB Issue
    You broke the first rule of modding, don't mod unless you can tune
    a ZZP out of the box PCM tune it just a generic tune meant to cover a variety of cars, if you can get your way to a guy with a tuner you will be 50 times happier with your car, it will have more power and probably get better mileage than a ZZP pcm
  1. Ported TB?
    By YoungGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2008, 05:32 PM
  2. ??ported Supercharger??
    By BLACKEDOUTGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2008, 10:22 PM
  3. Ported LIM?
    By Sabrewings in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2008, 03:02 AM
