Thread: GTP Fuel pump.. Will a GT pump work?
Results 1 to 11 of 11
  1. #1 GTP Fuel pump.. Will a GT pump work?
    SE Level Member azmattaz06's Avatar
    Feb 2009
    Tucson
    I have a GTP with a bad fuel pump, But i have a brand new one from a GT i believe sitting in my garage. On the actual pump itself i see there's a difference the GTP pump has that extra small black hose.. I was wondering if the pump itself from a GT can be used on a GTP? Not the whole thing just the pump. Thanks
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Autozone shows diff numbers, but thats for the module. I would just put in a 255lph if you are planning on doing anything to the car in the future.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  3. #3 Re: GTP Fuel pump.. Will a GT pump work?
    Feb 2009
    Tucson
    Limited budget so I don't have any plans on adding anything to the car at all.. Just can't find a good gtp fuel pump wanted to use this gt pump even though its slightly different
    Ohio
    You can swap out the whole canister for the gt canister and pump.. You can't put the gt pump alone in the gtp canister because of the gtp being venturi
  5. #5 Re: GTP Fuel pump.. Will a GT pump work?
    Feb 2009
    Tucson
    Ok so the GT Pump wouldn't work in a GTP canister? I think i'll try that then. Thanks
  6. #6 Re: GTP Fuel pump.. Will a GT pump work?
    You can swap out a venturi style for a non venturi style? All the hookups the same up top?
    Ohio
    Yes Dan
  8. #8 Re: GTP Fuel pump.. Will a GT pump work?
    Feb 2009
    Tucson
    Ok so it did work, I noticed a reduction in power though which im assuming is because the SE/GT pump doesn't pump as much fuel as the GTP pump would?
    May 2011
    United States
    If you noticed a reduction in power thats very bad. I doubt there was a actually a loss. That would point to the car leaning out in the top end which = no more engine.
    Sent from my Droid
    Ohio
    There is no difference between a gtp and n/a pump. I am betting on the one you put in was on its way out.
  11. #11 Re: GTP Fuel pump.. Will a GT pump work?
    Feb 2009
    Tucson
    Hmm.. Wouldn't doubt it, doesn't sound as loud as my original pump..
  1. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
  2. Will this pump work for me?
    By wking2 in forum General Tech Discussion
    Last Post: 06-16-2011, 08:01 AM
  3. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
