Thread: Misfire cylinder 4
Results 1 to 16 of 16
  1. #1 Misfire cylinder 4
    My car has a misfire on cylinder 4. Here's whats been done or replaced: Plugs(twice),wires(switched around and still misses only cyl 4)injectors (swtiched around ,still misses cyl 4) fuel filter was checked and replaced(old one was fine),heads were off and resurfaced/magnafluxed, new head gaskets etc,replaced pcm with a new one(still misfires on 4,switched ICM (twice and still misses),replaced and switched coils(twice and still misses on 4) Cam position sensor replaced and still misses, fuel pressure is fine,(misfire goes away or at least seems to upon normal driving),vacuum lines all check out fine,.... I'm extremely close to dumping this car. I've got 11 thousand tied up in it from the time I bought it a year ago august til now..... Any help would or insight would be appreciated. The car is sitting at a shop right now and I've basically told them they can have it until they find would could be going on....
    Snorlax strikes again.
  2. #2 Re: Misfire cylinder 4
    Scan it.
    That's what you need to get off of it.
  3. #3 Re: Misfire cylinder 4
    What info do you want? I scanned at thats all that comes up is the misfire on cylinder 4 and its idle only at this point
  4. #4 Re: Misfire cylinder 4
    Like a tuner scan.
    Like an aeroforce scan.
    Something that tells us something.
  5. #5 Re: Misfire cylinder 4
    I'll see what I can do since its at the shop.
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    COMPRESSION TEST!
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  7. #7 Re: Misfire cylinder 4
    Have you done a compression/leak down test?
  8. #8 Re: Misfire cylinder 4
    Bam, double post winning.
  9. #9 Re: Misfire cylinder 4
    Yes. There was a test done earlier this summer. Showed 70-80 psi in cylinder 4. This is why I tore everything down again and had the heads gone through. It was determined that the heads needed resurfacing etc. After all that was done , I checked the pistons,block etc and it was fine. Everything was put back together and I had another compression test done and all 6 cylinders were perfect. I have heard of rare occasions of cam lobes being worn or w/e and causing issues like this ...
    May 2011
    United States
    When does it miss? Idle? Under load? I would do another compression and leakdown test. Does it use any oil?
    Sent from my Droid
  11. #11 Re: Misfire cylinder 4
    Just misses at idle. Goes away under load or driving... The latest compression test was performed monday and all was fine
  12. #12 Re: Misfire cylinder 4
    oh yeah no oil loss either. This was an L32 swap and the motor basically has less than 600 miles on it since the guy built it.
    May 2011
    United States
    Quote Originally Posted by RamairGTP2 View Post
    This is a classic symptom of low compression.
    Sent from my Droid
  14. #14 Re: Misfire cylinder 4
    sympton yes but all the cylinders are right where they're supposed to be.
  15. #15 Re: Misfire cylinder 4
    Took the car out today from the shop.... Used the scanner and watched all the numbers.... Spark was between 30-40 under normal load/speed, one random multiple misfire showed up when I got back from driving(car was idling) cylinder 1,3 and 4 then back to cylinder 4 for misfire..... Absolutely zero misfires when driving.. only 4 began to misfire when letting off the gas or idle.... Fuel trims were perfect and all other sensors were functioning as they should....
  16. #16 Re: Misfire cylinder 4
    Pretty odd.. consider trying an ICM.
  1. Misfire on cylinder 3 and 4
    By bhuyser in forum General Tech Discussion
    Last Post: 09-08-2011, 11:17 AM
  2. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  3. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  4. Cylinder 3 misfire...please help!!!
    By swifty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2010, 07:21 PM
  5. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
