Thread: Did your car pass state inspection after an EGR delete?
Results 1 to 12 of 12
  1. #1 Did your car pass state inspection after an EGR delete?
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    I deleted the EGR and had ZZP shut the codes off. I can see with my scanner that everything is set to complete but the EGR its stuck at incomplete. Did anyone else have this problem? I am about to leave for DE state inspection and am not looking forward to a fail.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: Did your car pass state inspection after an EGR delete?
    Happy failing...
  3. #3 Re: Did your car pass state inspection after an EGR delete?
    you finna fail.
    however, my state you can have a couple of the tests incomplete and still pass without issue. you just cant have an SES light on.
    i passed without an EGR, but i had the codes set appropriately (not like you have).
  4. #4 Re: Did your car pass state inspection after an EGR delete?
    I passed with an egr, but set to never set any code. Like Bio said...seems like yours isn't set properly.
  5. #5 Re: Did your car pass state inspection after an EGR delete?
    doesn't the "no report" setting set the check test to ready?
    i haven't seen the screen of a tuner for a long time.
  6. #6 Re: Did your car pass state inspection after an EGR delete?
    Yes it does. But EGR can also be set to the diagnostic at 284F which should also leave it ready.
    Apr 2012
    Middletown DE
    This site depresses me at times.
    Sent from my Galaxy Nexus using Tapatalk 2
    1993 Oldmobile 88
    Apr 2012
    Middletown DE
    I also sent an email to zzp
    1993 Oldmobile 88
  9. #9 Re: Did your car pass state inspection after an EGR delete?
    Quote Originally Posted by acidcrashdburnd View Post
    That woudl depress me
  10. #10 Re: Did your car pass state inspection after an EGR delete?
    Houston
    In Texas you can only have one "not ready". I have an egr delete and high flow cat so I had two not readys. The cat codes are set to no report. The egr codes are set to report but not trip the MIL. I had to install an egr to get it to pass. Then re deleted the egr after the inspection.
    Apr 2012
    Middletown DE
    I passed! Now I'm sitting in the DMV and it smells like a nasty tacobell fart. I'm ordering LAGLESS plate today too.
    1993 Oldmobile 88
  12. #12 Re: Did your car pass state inspection after an EGR delete?
    Congrats..
  1. MA inspection with HPTuners
    By Silver GTP in forum Northeast
    Last Post: 07-23-2012, 05:55 AM
  2. Eaton M 90 Inspection??
    By jsnyder49090 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-11-2012, 05:57 PM
  3. Replies: 2
    Last Post: 02-14-2012, 08:47 PM
  4. Washington State Emmissions, What do I need to pass?
    By BoilerTom in forum General Tech Discussion
    Last Post: 02-03-2012, 11:00 AM
  5. Passing Inspection
    By blueguy in forum General Tech Discussion
    Last Post: 02-22-2009, 11:52 PM
