Thread: P0171 help please
Results 1 to 20 of 25
  1. #1 P0171 help please
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    i have a p0171 and a 1133 that will not go away. so far i have replaced all vacuum lines, replaced lim gaskets, replaced TB gasket, fixed egr leak, relpaced o2 sensor. my LTFT at idle are 16.4 and STFT is 0, WOT is 11.3 for LTFT. there are no vacuum leaks i have checked with a can of TB cleaner. my next move is to just sell the car any help would greatly apprciated
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  2. #2 Re: P0171 help please
    Have you tried cleaning your MAF? Check your pvc valve?
  3. #3 Re: P0171 help please
    Sep 2012
    bridgeport,NY
    cleaned the MAF how would i check pcv?
  4. #4 Re: P0171 help please
    Buy a new one they are $3 BWD PCV307 - PCV Valve | O'Reilly Auto Parts
    But your car is dumping fuel hence the 16.4 LTFT at idle.
  5. #5 Re: P0171 help please
    Pull it out and if it rattles it's good. Did you check your egr to see if it's leaking?
  6. #6 Re: P0171 help please
    He said he fixed egr.
    When was the last time you changed your fuel filter?
  7. #7 Re: P0171 help please
    Sep 2012
    bridgeport,NY
    egr was leaking out the connection on the exhaust manifold i replaced the missing bolt today and the codes are still haunting me
  8. #8 Re: P0171 help please
    I know why your running lean. Its a problem with 01+ cars and the cat tests that are performed by the pcm. Remove the o2 sim and put an 02 in the pipe somewhere. You will still get the cel for not haveing a cat but then your car will stop dumping fuel.
    http://www.grandprixforums.net/remov...know-7092.html
  9. #9 Re: P0171 help please
    Sep 2012
    bridgeport,NY
    tried that still same issue, the cat is still on the car. if it matters the TB and MAF sensor are from a 97
  10. #10 Re: P0171 help please
    You tried removing the o2 sim?
  11. #11 Re: P0171 help please
    Sep 2012
    bridgeport,NY
    i plugged the o2 sensor back in and still same issue sorry to anyone that thinks im a pain in the ass i need to get this resolved before the end of next month inspection is due
  12. #12 Re: P0171 help please
    Quote Originally Posted by Erik Adam Rodriguez View Post
    Yes that matters.
  13. #13 Re: P0171 help please
    Cam the 97-99 are different than the 00+ right? Or was it 97-98 then 99+?
  14. #14 Re: P0171 help please
    Sep 2012
    bridgeport,NY
    so would the older maf sensor be sending the wrong reading to the motor and causing a lean condtion
  15. #15 Re: P0171 help please
    Probably.
  16. #16 Re: P0171 help please
    97-98 are a different tb/maf 99-03 are the same.
  17. #17 Re: P0171 help please
    Sep 2012
    bridgeport,NY
    cleaned MAF again and installed poly dog bones. cleared codes and light is off for now, boost only at 3.22 lbs. ?
  18. #18 Re: P0171 help please
    Sep 2012
    bridgeport,NY
    seafoamed car today, noticed a little difference performance wise. put clamp on brake booster hose. only other vacuum line that would leak is the one that runs to the front of the car on the body next to trans. Light is back on with same code. next thing would be pcv valve getting new one tomorrow, any other ideas or suggestions?
  19. #19 Re: P0171 help please
    take the old pvc valve out, and shake it, if it rattles, its ok. you can clean it out with some brake cleaner if you want as well.
  20. #20 Re: P0171 help please
    Sep 2012
    bridgeport,NY
    pcv valve was bad changed it and fixed leaking fuel line. now car misfires and has same code as before. the stft is no longer at 0 all the time but ltft is 16.4 at idle and decreases with throttle goes to 0 at wot. all possible vacuum leaks have been fixed and i checked and cleaned the battery terminals and cables. can some please tell me the mv reading of a healthy o2 sensor, o and my vacuum reads 10 to 13 inhg. at idle ?
  1. 98 GP GT 3800 with P0171 off and on?
    By Fritcr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-31-2012, 01:05 AM
  2. p0171 help
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-14-2012, 08:07 AM
  3. Hi I'm new and have a p0171 code, can you help?
    By falconjohnd in forum Engine
    Last Post: 12-15-2011, 07:45 AM
  4. P0481 & p0171
    By Biohazed in forum General Tech Discussion
    Last Post: 04-26-2011, 09:51 PM
  5. p0171
    By sca555 in forum General Tech Discussion
    Last Post: 04-03-2011, 02:37 PM
