Thread: Help me out. Suggestions??
Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
  1. #21 Re: Help me out. Suggestions??
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    That's exactly why I didn't buy headers in the first place, but then I found some used coated S&S headers for $250 shipped, which was about what I paid for the powerlog/downpipe setup I currently have. If you want some cheap decent headers consider getting some SS Autochrome ones, they're stainless steel and only like $350 shipped.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  2. #22 Re: Help me out. Suggestions??
    Topeka, KS
    Quote Originally Posted by Smokin2000gtp View Post
    SS AUTOCHROME are those the ones off ebay?
  3. #23 Re: Help me out. Suggestions??
    Jul 2008
    Dekalb, IL
    Yep, and they are also known as XS Power headers too.
  4. #24 Re: Help me out. Suggestions??
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    Quote Originally Posted by Boger's99GTP View Post
    3.Ported front manifold is NOT a plog. yes they are similar but they are different.
    Yes true thanks for pointing that out, kind of like the difference between a ported throttle body and one of ZZPs high velocity tb's. Both for the same purpose but are different products. [and plog is better then ported front manifold]
    And yea as i mentioned the headers would be the better choice if you have the time and money. Only two problems with that are price and instillation difficulty. If you have little mechanical experience they are a bit more difficult to put in then people think. This your DD and you don't need it being out of commission for a long time.
    The plog and DP are two separate parts so therefore can both be installed at separate times.
    Also if you plan on purchasing headers make sure you get a name/type that people have had experience with. Last thing you want is a set of headers that you have to fabricate for a while trying to get them not to leak. Hell i have even known pacesetters to cause a bit of problems with leaking and they are the most common headers on here.
    2006 Grand Prix GXP
  5. #25 Re: Help me out. Suggestions??
    SE Level Member keenan00gtp's Avatar
    Oct 2008
    Iowa
    Quote Originally Posted by DnaProdigy View Post
    What would it take to install headers? (Time, money, supplies?)
  6. #26 Re: Help me out. Suggestions??
    SE Level Member acdv72's Avatar
    Oct 2008
    Simsbury CT/Williamsport PA
    since this is a daily driver, consider your driving habits and the behavior of our cars. stock GP brakes suck, bottom line. theyre also not known for their handling (to understate the problem). so if you tend to drive aggressively, consider putting a little into each area. it could be faster, stop shorter, and handle better. it really depends on your personal preference. you can lower your car over an inch and put GR-2 shocks on for about 500 bucks. 12 inch front brakes for $140. and all that you could do in a day if youre competent and have have tools (esp. an impact gun). i dont know where you live in iowa, but from what ive seen maybe you guys dont have enough corners out there to bother with suspension, heh.
    SLP CC Headers & DP / Cat-less & 2 3/4" back / CAI / Bored TB w/ spacer / Poly Upper Mounts / 104s / 180 tstat / Underdrives / 1.0 PCM / 3.4"/ -- 0 KR -- / 12" brakes / Sway Bars / Trailing Arms / Lowered on Vogtlands and KYB AGXs
  7. #27 Re: Help me out. Suggestions??
    Donating Users blowfishRus6's Avatar
    g.a.
    took me about 4 hours to take the old exhaust off and get my headers in there (just to find out it was a tight squese and they dident fit, 04 plus problem, fix is on the way tho)
    the hard part is getting all the old exhaust off. those bolts have been on there for a while so some like to break off. if that happpens mine as well cut the hole bolt off and get some new ones. i would recemend new bolts anyways. its best to spray something on the bolts prior and let it soak in. pb plaster or something. i used wd-40
    for pacesetters are any that are know to leak your gonna want a lot of rtv and some band clamps or whatever. with enough rtv and clamps you can get them to seal properly.
    pretty much the hard part is getting the old exhaust out. its not that dificult tho. if you have someone to help that is decently mechanicaly inclined you should have no problem.
    one more thing. ive heard the EGR is hard to get on to most headers. if so i have heard you can remove it with out an ill side effects, that has to be tunned in the pcm tho.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  8. #28 Re: Help me out. Suggestions??
    Jul 2008
    New York
    Quote Originally Posted by keenan00gtp View Post
    I really hate giving estimations about time but i would say its in the ballpark of three hours. Could be done in as little as 1 1\2 i would imagine or well over 3 hours [rusty, bolt breaks etc]. Please don't think this is something you can just smack like you see in horsepower TV or something. Where they say "now were going to install the headers, all you have to do is remove the old front and rear manifolds...blah blah blah and then install the new ones and your done" 30 seconds later. Many things to be careful of, which i could list if you are actually considering investing the time and $.
    Money, it depends on which namebrand you buy. The paesetters from ZZP start at $360. Their higher model stainless headers stat at $700. The Other Guys headers go for $750.
    Supplies, some one who has actually installed these would be better to comment on this.
    2006 Grand Prix GXP
  9. #29 Re: Help me out. Suggestions??
    GT Level Member adidasdude1061's Avatar
    Jul 2008
    P-Town, MN
    What's a good tuner to buy? Can it be bought cheap, like off of ebay or something?
    '97 BLACK GTP--Chrome K&N CAI--3.5" MPS--3" RT Cat Downpipe--180*Tstat--Tuned PCM--Alpine 9886--Kicker Amp - 2 12" Kicker L7's--ALT boost&rewire
  10. #30 Re: Help me out. Suggestions??
    Bloomington, IL
    ZZP Wizair cold air intake from zzperformance.com
    3.5'' Offroad pipe
    ZZP PCM
    180 Deg. Thermostate
    If you do all these you should be able to safely drop a pulley size which will give you great gains
  11. #31 Re: Help me out. Suggestions??
    TDCRacing
    Guest
    Quote Originally Posted by ssm90GT View Post
    3.5'' Offroad pipe
    ZZP PCM
    Wizair intakes are expensive. Mine are not. The wizaired performes exactly as mine does but is nearly twice the price.
    I have never heard of a 3.5'' down pipe. Even if there was one it would do no good to have it unless your whole exhaust system is 3.5''.
    Don't get a zzp pcm because they are garbage
    Might as well go with a 160*
    I doubt you will be able to drop puller sizes because most stock cars have 2-5* of KR to begin with. And thesemods listed above certainly wont get rid of that.
    First thing you need to do before you start dropping pullies is get a scan tool. No one can tell you what you need to do or what you need before you do that.
    If you dont have the money for a scan tool you can start with the more common mods such as an FWI or thermostat. You don't have to worry about scanning when you put those on.
  12. #32 Re: Help me out. Suggestions??
    Donating Users
    W-S, NC
    3.5'' Offroad pipe
    ZZP PCM
    Good mods but there is No way you can assume that those mods will let you drop a pulley. Its getting kinda old having to repeat this nothing against you personaly.
    1. The intake is a great choice, but a homemade FWI will net similar gains and cost less.
    2. 3.5 offroad pipe? im guessing h'es refering to a downpipe. Ive never seen a 3.5 dpunless its some crazy custom part and at that size would be pointless. You can go with either a 2.5 or a 3 inch downpipe. The "offroad" is a downpipe without a catalytic converter. Check local emission laws to see if a catless dp is legal.
    3.ZZP PCM.....I wouldnt go with ZZP. They have been having problems with their PCM's lately. I would go with Intense or Overkill.
    4. 180* thermostat is a good choice but your stock pcm turns you fans on when the temp reaches 195*. Id would do a aftermaket pcm Intense/Overkill first, they have the fan turn on point @ 180-185*.
    There are a few more mods that should be done as a precation. A ZZP powerlog or headers (if you can afford them), Autolite 104 spark plugs. and U-bend delete(if you get a catted or catless DP that will take care of the u-bend delete). Then come the most important part. Find a scanner to show if you have any knock retard. Scan before and after the pulley install to make sure you have no knock.
  13. #33 Re: Help me out. Suggestions??
    Donating Users
    W-S, NC
    TDC's a fast lil bastard lol But hes exactly right.
  14. #34 Re: Help me out. Suggestions??
    TDCRacing
    Guest
    Lol Glad we agree
  15. #35 Re: Help me out. Suggestions??
    TDCRacing
    Guest
    Quote Originally Posted by adidasdude1061 View Post
    The only tuner that I would recomend is the HPTUNER wich starts at 500.00.
    This isnt a stage 1 tune stage 2 tune type of thing. You have to learn about how to tune and how to work this tuner before you just ''start tuning''
    You just have to be patient.
    HPTuners.com >> Performance At Your Fingertips is where it's at.
  16. #36 Re: Help me out. Suggestions??
    TDCRacing
    Guest
    I have had the pacesetters and have had the zzp stainless 700 dollar headers. Both leak both need improvements. ZZP's are way better in workmanship and quality and leak FAR less than the pacesetters.
    ZZP's are actually the same price as the togs because you have to buy a dp and it is not included like it is in the tog's package.
    I had no leaking issues with the p-log and DP setup with the stock rear manifold.
    Install time for headers? If you're setup is stock right now then plan on around 4hrs if you kinda know what your doing, can of PB Blaster and some broken bolts.
  17. #37 Re: Help me out. Suggestions??
    Donating Users
    W-S, NC
    He better have some pb blaster and be ready for broken bolts if he does a plog. The crossover bolts can be a p.i.t.a.. I broke one myself.
  18. #38 Re: Help me out. Suggestions??
    Jul 2008
    Germantown, Maryland
    Was fooling with my VE today with Josh... while driving home I had the scan on and yea... at WOT i would see 3-5* of KR... still fooling with the tune but it is better than before. I'm wondering how bad my knock was before I started the tune :X
  1. Mod Suggestions For Beginers
    By TDCRacing in forum General Tech Discussion
    Last Post: 06-26-2008, 01:51 AM
  2. Tire Suggestions
    By Risinnfallen in forum General Tech Discussion
    Last Post: 05-27-2008, 04:11 PM
  3. Muffler suggestions
    By DanGTP in forum General Tech Discussion
    Last Post: 03-29-2008, 11:34 PM
  4. MOD suggestions please
    By scoobyydooooooo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 07:59 PM
  5. Buying a TV. Suggestions?
    By thermanlee in forum Off Topic Discussion
    Last Post: 01-15-2008, 03:56 AM
