Thread: My Cruise is not working. please read.
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21 Re: My Cruise is not working. please read.
    Check your 3rd brake light and if the bulbs are still good check to see if it works in 3rd gear.
  2. #22 Re: My Cruise is not working. please read.
    HUDSON
    This paragraph is from Rossler Transmission Inc.
    3 speed and overdrive transmissions: Caution never shift into neutral position at high speeds. This will cause internal components of the transmission to rotate 2 and ½ times faster than your finish line RPM. (Example, If your car’s finish line RPM is 7,500 RPM’S and the Transmission is shifted to neutral then the internal components will spin at 15,000 RPM’s THIS IS VERY DANGEROUS! The parts are spinning so fast, they can explode, turning your transmission into a shrapnel type bomb possibly causing bodily injury and death.
    At one time the cruise in my GTP stopped working also, and it turned out to be that the 3rd brake light bulbs where both blown out. After installing new bulbs, the cruise control functioned normal again.
  3. #23 Re: My Cruise is not working. please read.
    Grand Rapids, MI
    Meh. I was getting on the interstate one time and I thought it was in 3 so I was gonna shift to D and let it go into 4th. Well apparently I was in D and it went into N. It was no problem for me. Granted I'd never do it on purpose. Also, one of my bulbs in the 3rd brake light is out and cruise still works. Odd.
  4. #24 Re: My Cruise is not working. please read.
    We arent saying that doing it once is going to make everything explode into a ball of fire, but if one continues to do it, its going to wear something out sooner or later.
  5. #25 Re: My Cruise is not working. please read.
    Grand Rapids, MI
    Lol I know. I didn't mean it like that But the same is true with many things, the whole damn thing is gonna wear out eventually.
  6. #26 Re: My Cruise is not working. please read.
    Jul 2012
    Saskatchewan, Canada
    Thanks for the info on the transmission.. never thought about it that way.
    Changed the Cruise box on the fender. still doesn't work.
    please correct me if i am wrong,
    the trac control uses the wheel sensors to 'see' a difference in wheel speed.
    there transmission will have a input speed sensor(shift points and the like).Or would that be engine speed(rpm)?
    and an output sensor. is there only one 'output' sensor.
  7. #27 Re: My Cruise is not working. please read.
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    has this problem been solved?
    I have a similar issue
    02 sedan, top swap
  8. #28 Re: My Cruise is not working. please read.
    Dec 2010
    long prairie, mn
    bump
  9. #29 Re: My Cruise is not working. please read.
    Jul 2012
    Sorry. I'm not of much help. I still have no cruise. It's going into the shop for an O2 sensor this week. Hopefully he can help us out
    Quincy, Mass
    If your high mount brake light had a bulb out or you have led bulbs in there it will stop your cruise control. I know from experience.
    No more GP 04 Impala SS Indy:
  11. #31 Re: My Cruise is not working. please read.
    Grand Rapids, MI
    Odd. I have one of the bulbs out in the 3rd light. Works fine.
  12. #32 Re: My Cruise is not working. please read.
    All have to be out for cruise to not work
  1. Replies: 3
    Last Post: 07-24-2012, 08:41 AM
  2. Cleaned my throttle body..cruise control stops working
    By GTLGDP in forum General Tech Discussion
    Last Post: 03-21-2012, 04:31 PM
  3. Cruise Control Not Working
    By Curt7 in forum General Tech Discussion
    Last Post: 07-07-2011, 08:10 PM
  4. Why is my cruise control not working?
    By bronzegp in forum General Tech Discussion
    Last Post: 04-12-2011, 05:44 PM
  5. Cruise Control stopped working
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 07-03-2008, 11:48 PM
