Thread: Dropping Engine & Transmission out the bottom
Results 1 to 10 of 10
  1. #1 Dropping Engine & Transmission out the bottom
    GT Level Member NR92's Avatar
    Atkins, Ia
    picked up a 96 olds LSS for the purpose of parting out, kinda made the decision to drop the motor and trans out the bottom, one reason is that i want the sub frame and also i heard it can be easier, with that being said if i have to get a little violent with anything outside of the motor and trans that would be fine
    questions are
    *is it harder/more time consuming to drop it vs pulling it,
    *ball park on time it would take?
    *who here has done it without a lift?
    any advise you have would be much appreciated
    also because im not with the car right now and im too lazy to look, is the motor have any mounts bolted to the sub frame aside from roll resisters?
    potently useful information
    *done many engine swaps but never pulled one out the bottom
    *its a supercharged motor
    * don't have a lift, just a cherry picker and few jacks and some jack stands
    *plan to do it myself but an extra hand can be had if needed
    *i want to drop it out the bottom for ****s and giggles
    2004 GTP Comp G -- Sold
    2006 GTO Magnuson supercharged
    2007 Ram 2500 QCSB 4x4 5.9 Cummins, Efi live, Exhaust, Intake N'stuff
  2. #2 Re: Dropping Engine & Transmission out the bottom
    subframe will never line up if its pressed against the body of the car.
    Have to get it close enough for bolts to thread without touching it.
    Otherwise it bends the chassis and wont line up.
  3. #3 Re: Dropping Engine & Transmission out the bottom
    Atkins, Ia
    im sorry i dont understand
  4. #4 Re: Dropping Engine & Transmission out the bottom
    It will make sense when you try to put the subframe back in.
  5. #5 Re: Dropping Engine & Transmission out the bottom
    Portland Oregon
    Matt's just being Matt again. What he means is that when you re-install the subframe in whatever vehicle you're putting it in, make sure you get it to the point where you can start the bolts by hand and run them up that way, don't lift the subframe all the way to the body. To now answer your question, if it's just like any W-body you should be able to drop it with minimal effort. Disconnect wiring harness, steering link, lower ball joints from the steering knuckles and pop the axles. Or if you want to drop the suspension with it, disconnect the top three bolts on the strut mounts.
  6. #6 Re: Dropping Engine & Transmission out the bottom
    this is a parts car he taking apart.
    you need your cherry picker to lift the car, a dolly or 2 dolly can help roll it out from under the car.
    you can drop the whole front end struts and all, with the rack everything.
    un hook engine, the rack from the column, the brake lines, un bolt the strut tops, support the sub frame with jacks, take sub frame bolts out, lift the car up. slide it out, or push and pull the car around with the picker if need be, or possible.
    Atkins, Ia
    Man you guys are awesome!!
  8. #8 Re: Dropping Engine & Transmission out the bottom
    I always do it with just a floor jack and jack stands. If your unhooking everything it should take like 3 hours maybe. If your not trying to save to much 30 min
  9. #9 Re: Dropping Engine & Transmission out the bottom
    I haven't dropped out the bottom w/o a lift. However Hitman just did and said it was pretty easy to roll, you leave the tires on and the whole thing rolls nice.
    On the 88, all your engine/trans mounts are on the bottom except the TA mount on the passenger side. That might be a pain point for you. Because that holds the engine/trans on that side. The only other mount is a dogbone from subframe to the bottom of the trans. It might be enough though. You have a lower front and rear trans mount on the driver side..then that one doggie on the passenger side. it might not fight. On that TA mount.. lift a little..pull the one main bolt and it should all slide rignt down.
    Atkins, Ia
    Drop the whole thing out last night, I was really taking my time and stopping to screw with stuff and still got it out in 4 hours or so, if I was really trying I don't think 2 1/2 hour drop would be hard, thanks again guys for the info
  1. Transmission/engine
    By RALM in forum General Grand Prix Discussion
    Last Post: 09-03-2012, 04:50 PM
  2. Function of the three metal tubes on the inside, bottom of the transmission?
    By fju2 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-26-2011, 11:26 PM
  3. Engine will be done soon...What to do w/ Transmission?
    By NineD9GT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2011, 02:06 PM
  4. bottom swap, or how i learned to rebuild the bottom end completely
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2009, 03:37 AM
  5. Engine and Transmission Compatability
    By slednut in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2009, 10:20 PM
