Thread: Can't refuel
Results 21 to 40 of 41
  1. #21 Re: Can't refuel
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    I was getting this problem ALOT in my impala a while back an di popped the hood and it turned out that the purge canister line attached to my TB was twisted and wasnt getting flow? i guess...I straightened it up and i was allowed to refuel again. Then a month ago i switched to a gen v and my gen v to n * adapter didnt have the nipple on the front so i left it unhooked and the car didnt let me fill up. So my guess is that purge canister lien that attaches to the small brass nipple on the front of your tb near the front valve cover.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #22 Re: Can't refuel
    I just only insert the handle half way.
    works every time.
  3. #23 Re: Can't refuel
    Pennsylvania
    ...just the tip?
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Already said inserting it partially fully upside down side to side all in the hips. Didn't work. Unhooked the evaporation line on the tb it let me fill up. I'll be looking into it later.
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  5. #25 Re: Can't refuel
    It's funny when people post that they have an issue. Yet..they dont' tell us what the car is or year etc.
    Oct 2011
    MI
    Probably because I'm in the supercharged section and the evaporation system doesnt change much between the 97-03 to 04-08 or any gm vehicle really from the same time frame. When it's vehicle specific I'll be sure to post it.
  7. #27 Re: Can't refuel
    Minnesota
    Actually it does. In IIRC 00-up cars the Charcoal canister is on top of the tank instead of on the driver rear with the purge solenoid.
    Be sure to post up results of peoples suggestions.
    Oct 2011
    MI
    Same type of system not placement
    Oct 2011
    MI
    I've already done what everyone has suggested and then some. I''ll have a few hours on Saturday to figure it out. I'll use a tech2 and Mitchell1 to getter done.
  10. #30 Re: Can't refuel
    Pennsylvania
    Almost makes you wonder if it's plugged up, somehow, which I feel should be really unlikely. Able to get a tube in there and siphon some out?
  11. #31 Re: Can't refuel
    Minnesota
    Unless you have a bad fuel neck the only other thing it could be is the line going from the tank to the canister to the purge.
    If you have the lines disconnected from the tank it should be venting directly to open air.
    Or someone keeps putting soap in your gas tank because they think you are an asshole? lol
    Oct 2011
    MI
    I bought the car it's been like this since got it a month ago. Car is parked in the garage anytime I'm home. Ill post back tomorrow after I get her figured out
  13. #33 Re: Can't refuel
    SE Level Member Danarchy's Avatar
    Sep 2012
    works every time.
    We had a '99 Grand Am with this issue, and I just retracted the nozzle a bit and slowed down the flow of the pump. Had to find the sweet spot, much like other activities :P Couldn't just ram it in and go to town. Ok I'll stop now.
    2005 Grand Prix GT - Stock - K&N Drop-In, Deer Whistlers on the Bumper
    2007 Chevrolet Silverado LT (NBS) Ext. Cab 5.3L V8
  14. #34 Re: Can't refuel
    gardner,mass
    solutions are posted now its you guys job to get off your asses and do something instead of posting 100 times how do i fix this. The possibilities are here we cant fix it for you unless you bring the car to us. It can be multiple things, we cant see whats going on in your car over the internet.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  15. #35 Re: Can't refuel
    Pennsylvania
    Easy killer. He said he tried the things suggested thus far two posts back. Which is why he's getting weirdos posting about shoving things in his tank.
    Oct 2011
    MI
    I changed my fuel cap because it looked beat... still had the problem so I replaced the vent solenoid/canister located by the fuel neck.. it was only $20 solved my issues.
    Sent from my SPH-L710 using Tapatalk 2
    GTP Level Member apierce1289's Avatar
    United States
    Probably your filler neck. I had this issue on an old car and replacing that fixed it.
    Sent from my DROID RAZR using Xparent Red Tapatalk 2
    Gremlins always seem to show up in pairs, or groups of three with our cars...
    Oct 2011
    MI
    I just said problems were solved
  19. #39 Re: Can't refuel
    Minnesota
    So I was right. Hmmm lol
    Glad you got it fixed.
    Oct 2011
    MI
    Yeah I pulled down the vent solenoid. And used my power probe to apply ground and power manually. It would work upside down but not in the right side up position likes its mounted. Gotta love dead spots. Thanks for the input from anyone with suggestions hopefully someone else with this problem has some info to go by while figuring it out. I had a Tech2 so it wasn't too difficult to see what wasn't working
    Sent using my Galaxy SIII on Tapatalk
