Thread: Supercharger Wastegate Solenoid
Results 1 to 5 of 5
  1. #1 Supercharger Wastegate Solenoid
    SE Level Member dblisle's Avatar
    May 2012
    Keene, NH
    I've been searching all over the internet to find out where the Wastegate Solenoid is located on my Eaton M90 Supercharger. I'm getting the Check Engine code P0243 Supercharger Wastegate Solenoid A Malfunction. I believe it is the Black Cylinder on the front right corner of the Supercharger if your facing the engine from the front of the car.
    Can anybody help?
  2. #2 Re: Supercharger Wastegate Solenoid
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    its the black rectangle that is right below the round actuator
  3. #3 Re: Supercharger Wastegate Solenoid
    May 2012
    Keene, NH
    Thank You
  4. #4 Re: Supercharger Wastegate Solenoid
    Sep 2012
    bridgeport,NY
    welcome and its called the boost bypass solenoid
  5. #5 Re: Supercharger Wastegate Solenoid
    May 2012
    Keene, NH
    Thank you, nothing I could find on the net would confirm that they were the same
  1. Wastegate prob.
    By 420in713 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2011, 11:51 AM
  2. Supercharger Bypass Solenoid
    By DPSJosh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-01-2009, 11:28 PM
  3. If i need map again what feeds wastegate
    By rodman in forum Turbo
    Last Post: 07-07-2009, 04:14 AM
  4. Wastegate
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 04-18-2009, 04:31 PM
