Thread: 99 gtp not starting
Results 1 to 9 of 9
  1. #1 99 gtp not starting
    Aug 2012
    Plymouth MI
    Alright so the deal is this I just bought this car not too long ago. I haven't been able to plate it yet because i didn't expect my insurance to be so high. While i was waiting to get the money together i would start it every now and then drive it on the temp plate it always sounded like it was trying hard to start but it always started the first crank. I went to start it the other day and it gave one crank and died i still have lights although they are very dim. I don't know if its related but the gas gauge light was always really dim. My car is stock expect for a stereo power acoustik DVD and i believe the battery is like a megatron 2. So with all the details my question is this i am thinking its the alternator but what should i pull to have tested first the alternator, the starter, or the battery?
    thank you in advance
  2. #2 Re: 99 gtp not starting
    check battery voltage then check for fuel and spark.
  3. #3 Re: 99 gtp not starting
    Sep 2012
    chicago
    Had same problem on my 98 ended up just being corroded battery connections or how old is the battery?
  4. #4 Re: 99 gtp not starting
    Aug 2012
    Plymouth MI
    So an update is this, my neighbor charged the battery for me it fired right up sounded nice and healthy. Although the positive terminal on the battery is not a permanent one and its a little corroded and i guess the wires might need replaced which leads me to believe its either that or the alt but he wont help me take the alt off to have tested and i cant do it myself he says it will be a pain and i was wondering if there is any truth to this or does he just not want to help me because i don't have the stuff to do it i don't wanna take it to a shop just for that
  5. #5 Re: 99 gtp not starting
    Its like a 10 min job to pull the alt if you take your time
  6. #6 Re: 99 gtp not starting
    Aug 2012
    Plymouth MI
    That's what I thought its like loosing the tensioner and taking off two bolts right? he was talking about the supercharger belt all this stuff i couldn't think it was that hard
    Quincy, Mass
    The alt is 3 bolts, 15mm heads on them, 13mm on the nut holding the wire on. Make sure you put the shortest bolt back in the right spot or it will go through the valve cover if its too long. It's not hard on these cars I think he was just being lazy.
    No more GP 04 Impala SS Indy:
  8. #8 Re: 99 gtp not starting
    Sep 2012
    chicago
    All you need to do is get a cheap volt meter and see what the voltage is at the battery with the car running no need to pull the alt. off
  9. #9 Re: 99 gtp not starting
    what he said,^^^^^^ but a load tester is a better test, that way you can test the alt, and the battery.
    also check you months of the battery, and the date, then do some math to see if the battery has timed out. once they hit the end of their life/months, they dont last long. especially if its sitting around and not being driven daily.
  1. starting
    By PontiacGT8 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2011, 12:43 PM
  2. Starting to mod my GXP - help me.
    By extreme in forum 5.3L V8 (LS4)
    Last Post: 09-11-2011, 10:28 AM
  3. starting to mod
    By LeThAlREMiX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2011, 08:38 AM
  4. Just Starting!
    By fpgt17 in forum Introductions/Noob Questions
    Last Post: 01-17-2011, 01:01 PM
  5. gtp not starting
    By mtz956 in forum General Tech Discussion
    Last Post: 12-04-2010, 07:46 PM
