Thread: Ltft @ 16?
Results 1 to 6 of 6
  1. #1 Ltft @ 16?
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Long term fuel Trim is sitting at 16...
    Someone mentioned its a vacuum leak.
    I've got a P0455 large evap leak and the check gas cap indicator on the DIC.
    -I already tried the carb cleaner trick didn't find anything under the hood.
    -I used my tech2 to command the purge and vent solenoids and they appear to be in working order.
    I'm going to try a new GM Gas Cap tomorrow. Because that's the obvious choice but what's weird is trying to fill up. it acts like it's got a full tank stopping the gas pump at the station. Wait a couple seconds and start filling again... if I squeeze the handle less it doesn't act up as quick... any thoughts?
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #2 Re: Ltft @ 16?
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    what are ur mods? i think my ltft was at like -5 until i got my pcm now i am at like 15 with the zzp pcm
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
    Oct 2011
    MI
    No mods really yet. App605 plugs..gutted cat and no res. K&n
  4. #4 Re: Ltft @ 16?
    LTFT of a maxed out +16.4 means you have a vacuum leak. it's trying to compensate and dump fuel in to richen up the car.
    i would fix your evap leak and then go from there.
  5. #5 Re: Ltft @ 16?
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    do a smoke test at your local dealer or shop
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
    Oct 2011
    MI
    Yeah smoke test was the next plan.. I tried carb cleaner everywhere no change in idle not even slightly.
  1. ltft?
    By jim97regalgs in forum PCM Tuning
    Last Post: 10-14-2011, 09:01 PM
  2. LTFT and O2 problems
    By ASCStinger in forum PCM Tuning
    Last Post: 10-13-2010, 05:38 PM
  3. LTFT all over
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2009, 10:07 AM
  4. ltft +12 help
    By DOUGLASMELTER in forum PCM Tuning
    Last Post: 10-22-2009, 06:39 AM
  5. Tuning LTFT's
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 04-10-2008, 08:37 PM
