Thread: Chasing low throttle misfire - Any suggestions?
Results 1 to 11 of 11
  1. #1 Chasing low throttle misfire - Any suggestions?
    SE Level Member BlackGS's Avatar
    Central Jersey
    I'm getting misfires on cylinder #2, but only when the throttle position is less than 5% (light cruising, idle, park, etc.). Any throttle over 5% and the misfires are gone. This started about 2 weeks ago right after I switched back to 93 gas from e85. I really don't think the switch back caused the problem - just a coincidence, but I thought I would mention it. When I'm cruising, the misfire count gets high enough that the TCC unlocks, so that is annoying, and I'd like to get this resolved. Any suggestions are appreciated.
    Here is what I have done so far:
    Swapped plugs - misfire stays on #2
    Swapped plug wires - misfire stays on #2
    Swapped coil packs - misfire stays on #2
    Swapped injectors - misfire stays on #2
    Cam is stock with 1.9 roller rockers and 105# springs. Spark plug in #2 looked great, and all plugs looked exactly the same. Car pulls very strong with no hesitation.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  2. #2 Re: Chasing low throttle misfire - Any suggestions?
    Do you have an ICM you can swap out?
  3. #3 Re: Chasing low throttle misfire - Any suggestions?
    Central Jersey
    I do not. I guess I could at least check all the connections to the ICM.
  4. #4 Re: Chasing low throttle misfire - Any suggestions?
    hows your tune look?
  5. #5 Re: Chasing low throttle misfire - Any suggestions?
    Central Jersey
    Quote Originally Posted by gtpsleeper View Post
    Tune is very good. I run open loop, but it is interesting that when I tried closed loop, the misfires seemed to get a bit worse. Since fueling in closed loop is more erratic with the up and down cycles, I can see how that could compound the problem.
  6. #6 Re: Chasing low throttle misfire - Any suggestions?
    Not sure I understand how tune could make one cylinder misfire unless you skewed that one injector heavily in one direction.
  7. #7 Re: Chasing low throttle misfire - Any suggestions?
    Central Jersey
    I agree. Tune might make the misfire count higher or lower in that one cylinder, but would not be the root cause. I have my front bank skewed very slightly higher, but that has been like that for years.
  8. #8 Re: Chasing low throttle misfire - Any suggestions?
    because I notice in my OL tune that if I ever go too lean or have a random lean spike my #2 is always the one that misfires... why? cuz its a grand prix... thats the reason I ask...
  9. #9 Re: Chasing low throttle misfire - Any suggestions?
    Central Jersey
    I found a replacement ICM to swap. Misfires remain on #2.
  10. #10 Re: Chasing low throttle misfire - Any suggestions?
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Have u checked the plug gap? Maybe it was conflicted while putting in or fouled....check the resistance in the wire
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    COMPRESSION TEST
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  1. Chasing stupid ABS light
    By FordMan77 in forum General Tech Discussion
    Last Post: 09-22-2012, 01:00 AM
  2. Having problem chasing down Random misfire
    By dubld24lo in forum Introductions/Noob Questions
    Last Post: 05-03-2012, 03:14 PM
  3. So I'm chasing after my friends dsm on the highway last night
    By Wotgtp in forum Track Sessions and Kills
    Last Post: 11-25-2011, 05:27 PM
  4. Chasing P0171 again
    By GTP in RTP in forum General Tech Discussion
    Last Post: 11-14-2011, 08:00 AM
  5. ltft chasing
    By shawnrandolph in forum PCM Tuning
    Last Post: 08-31-2011, 10:53 AM
