Thread: Misfire, running lean
Results 1 to 4 of 4
  1. #1 Misfire, running lean
    GT Level Member PontiacL32's Avatar
    Sep 2012
    Murray, ky
    I just bought a 2005 grand prix a month ago, since then i installed speed daddy headers. I have a slight misfire at idle when its in park, it dosent seem to happen while driving or idling in gear. i stopped and got the codes read, it has a few for the converter because its not there anymore. The other codes are P1133 for bank 1 sensor 1, and i replaced that sensor the day after i bought it when it still had the manifolds and converter. P0133 bank 1 sensor 1 slow response. P0243 supercharger wastegate soleniod.
    it also has brand new stock replacement plugs and wires, I also ran some fuel system cleaner thew it. I am going to be changing the lim gaskets this weekend and figured i would clean all the grounds and stuff while im in there. I also watched the boost bypass solined and it opens when its running and closed when its off. What do you guys think is wrong ?
    thanks
    -josh
    2005 Grand Prix GTP, 170,000 miles. Speed daddy headers with no cat, cone intake, MSD wires, flipped dog bones, transgo shift kit FOR SALE.
    2004 GTO six speed, stock for now.
  2. #2 Re: Misfire, running lean
    Misfires at idle are pretty common when modded, most of the time they happen and the PCM doesnt even sense it.
    And both those front o2 codes I have gotten right after I did my headers and then went away after a handful of times coming up.
    You might wanna get a tune for not having a cat, it does affect MPG's on anything 01+.
  3. #3 Re: Misfire, running lean
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    I have speed daddy headers and everytime I run 110 I get that code but after a few tanks it clears up just keep clearing it and see what happens
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  4. #4 Re: Misfire, running lean
    Sep 2012
    Murray, ky
    Okay, i was going to wait to tune till i have my other mods to put on and install and tune them all at once. will it hurt anything to drive it with headers and no cat for a few months with out a tune?
    I was ust thinking, the check engine light came on the day after i bought it and filled it up with 93 octane. i think the previous owners ran regular would this have anything to do with the bank 1 sensor 1 code on the brand new sensor? Because it threw that code when it still had manifolds and a cat.
    thanks
    -josh
  1. #4 misfire during boost, also bank 1 lean
    By petebjork in forum Introductions/Noob Questions
    Last Post: 06-01-2012, 11:44 PM
  2. Running lean?
    By MrTube in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-05-2012, 01:05 PM
  3. Running lean
    By camarofan1974 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2011, 03:25 PM
  4. running lean?
    By Brennan7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2010, 10:07 AM
  5. STILL running lean..why!?
    By BwolfGT in forum General Tech Discussion
    Last Post: 10-22-2009, 12:26 AM
