Thread: Spun bearing! swap to L26??
Results 1 to 12 of 12
  1. #1 Spun bearing! swap to L26??
    SE Level Member gixer2000's Avatar
    Braintree, ma
    Like the title says i spun a bearing in my 99gtp. Ive been told by a few people that i can use the l26 bottom end and swap the rest of my motor over. i just wanted to make sure that i can swap everything and if i would be better to use some of the l26 parts(if any of them work)
  2. #2 Re: Spun bearing! swap to L26??
    Barksdale AFB, LA
    L26 bottom end is a bit stronger than your L67 bottom end, as long as you get a 2005+ L26. The 2004 L26 used the same rods as the L36 since the sinter forged rods weren't in large enough production yet. You will get the higher compression with the L26 block and it might take a little tuning to get it running smooth again. The plus side is like I said it's stronger and you'll make more power on boost than a L67/L32 bottom end.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Spun bearing! swap to L26??
    Braintree, ma
    i got a 07 L26 with 9K miles on it. So i should be buying all the gaskets for a l67 and they will work with no problems..
  4. #4 Re: Spun bearing! swap to L26??
    Barksdale AFB, LA
    Quote Originally Posted by gixer2000 View Post
    All 3800's from Series II and Series III use the same head gaskets and lower intake gaskets.
  5. #5 Re: Spun bearing! swap to L26??
    Braintree, ma
    nice! thanks for the help
  6. #6 Re: Spun bearing! swap to L26??
    Braintree, ma
    I was just going through zzp's page to place the gasket order and im not sure what head gaskets i should use and if i need head studs or just buy new head bolts
  7. #7 Re: Spun bearing! swap to L26??
    Hoffman/Schaumburg, IL
    ^^Depends weather you want to take the heads off again..... and you'll gain a little MPG with the higher compression(if you drive the same as before, cause it only uses less fuel under vacuum, under boost is another story)
  8. #8 Re: Spun bearing! swap to L26??
    Braintree, ma
    I hope i dont ever have to take the heads off again! so does it make sense for me to buy the felpro's or something else.
  9. #9 Re: Spun bearing! swap to L26??
    GT Level Member Preotic's Avatar
    Missoula, MT
    You'll need a bigger pulley to go with that higher compression. If you plan not to take the heads off again you should just get felpros and stock head bolts.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  10. #10 Re: Spun bearing! swap to L26??
    Braintree, ma
    yea i hope i dont have to take them off again.i have a 3.4zzp mps pulley that i will be putting back on. im not sure if i should go bigger or not. mods are xp,SS intercooler,105 valve springs,pacesetter headers no cat,42.5 injectors, custom tune,180 drilled stat,al 103's,jp double roller,N*,LQ4 and a 3.4 i guess. do you think i should buy a bigger pulley
  11. #11 Re: Spun bearing! swap to L26??
    Missoula, MT
    If you were running a 3.25 and now you are adding more compression I would definately try the 3.4 first.
  12. #12 Re: Spun bearing! swap to L26??
    Had the same problem in my 99 GTP Superchared. Bought a crank kit/w bearings from Orielly's and it runs great. Cost less than 400.00.
  1. going on 4th Wheel Bearing
    By Toofastgs in forum Brakes/Suspension/Chassis
    Last Post: 05-16-2014, 04:24 PM
  2. Wheel bearing questions...
    By Iron Indian in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 11:05 AM
  3. Replace cam bearing with engine still in?
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2008, 09:05 PM
  4. Drive Sprocket Support Bearing
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2008, 05:50 PM
  5. Top end swap???
    By Randy_W in forum General Tech Discussion
    Last Post: 06-01-2008, 06:24 PM
