Thread: Whining noise
Results 1 to 15 of 15
  1. #1 Whining noise
    Sep 2011
    Indiana
    Hey guys,
    I have an 00 GTP with 80k on it. Recently I noticed something in the motor whines when idling. It's not incredibly loud but its gotten pretty annoying. I tried pinpointing the noise and it looks like its coming from somewhere below the supercharger. Any idea what it is? The car has a CAI and a 3.4 pulley so I dont know if that makes a difference. No I do not have headers, and the car has ran fine. I did replaced the rack and pinion at 77k. It does not make the whining noise if I turn the wheel like a bad pump or rack would do.
  2. #2 Re: Whining noise
    Sure it runs "fine", buts its not good for the car to run that pulley with ZERO flow mods.
    Check your trans fluid level while hot. Might be your issue.
  3. #3 Re: Whining noise
    Sep 2011
    Indiana
    thanks, i bought the car like this. i tried getting the stock pulley back on but my mechanic said he didnt have the right tool for it
  4. #4 Re: Whining noise
    being your at 80,000 miles and just got the car. now would be a good time to drop the pan and change the filter in the trans. your due.
    clogged filter can also cause the trans to whine. can also cause hard shifts.
  5. #5 Re: Whining noise
    Pennsylvania
    Whining sources:
    Low power steering fluid
    stuck pulley
    Bad snout bearing
    Broads
  6. #6 Re: Whining noise
    Sep 2011
    Indiana
    Here is a video I just took. What do you all think? Seems even louder in the video!
  7. #7 Re: Whining noise
    take one belt off at a time to see if that goes away. you can narrow it down like that.
  8. #8 Re: Whining noise
    Sep 2011
    Indiana
    Thanks! I did not know that! Definitely looking into that.
    Quote Originally Posted by SlowNA06 View Post
    Whining sources:
    stuck pulley
    Bad snout bearing
    Broads
    Thanks! last one is almost always guaranteed lol
  9. #9 Re: Whining noise
    Sep 2011
    Indiana
    Thanks, Ill try that.
  10. #10 Re: Whining noise
    Pennsylvania
  11. #11 Re: Whining noise
    Sep 2011
    Indiana
    lol how do you get the video to come up like that? im trying to edit my post with the video
  12. #12 Re: Whining noise
  13. #13 Re: Whining noise
    Sep 2011
    Indiana
    thanks! I cant figure it out lol Other forums are different
  14. #14 Re: Whining noise
    copy and paste the address into the next to last icon from the right, looks like a film strip. (in the reply box that is) and thats it.
  15. #15 Re: Whining noise
    Sep 2011
    Indiana
    I appreciate it! Im going to check the trans fluid tomorrow as well as removing the belt from the supercharger. I hope its an easy and cheap fix. This sound is annoying.
  1. Whining Noise?
    By BwolfGT in forum General Tech Discussion
    Last Post: 06-15-2013, 09:44 PM
  2. Whining noise?
    By Chiller449 in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-26-2012, 05:35 PM
  3. Whining/whistling noise
    By KadenGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-19-2011, 04:20 PM
  4. Whining Noise
    By silo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:50 AM
  5. Whining Noise
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2009, 11:23 AM
