Thread: Car Bogging :(
Results 1 to 19 of 19
  1. #1 Car Bogging :(
    gardner,mass
    i just got a 04 compg with 90k on it a month ago. Since then i have gone threw it as much as i could. New tr55s, wires, mobil 1,sc oil, egr delete, tb maf and pcv cleaned, sd headers, cai, 180 tstat, sea foamed gas oil and vac lines and now tomarrow im changing my fuel filter cus i had to special order it. Under heavy acceleration it will just lose all power for a second or two then pick up and go.
    Im hoping its just the fuel filter thats clogged or something and its getting a cutoff on gas for a second.
    Edit: oh ya ive also flushed the **** out of the dexcool in there and put some green in
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: Car Bogging :(
    To me if the fuel filter was clogged, it wouldnt just stop for a second and then pick up and go, because it would be clogged the whole time.
  3. #3 Re: Car Bogging :(
    gardner,mass
    ya well i did take it off to put a new one on but the parts store got me the one with the skinny and fatter inputs and i need the 2 fat inputs for mine, anyway i dumped it out and it was dirty. But what else could cause this there are no codes besides the obvious egr delete code and also i removed my cat for now until i get a chance to weld in my new on to the headers and no code has come up in like 300 miles
  4. #4 Re: Car Bogging :(
    gardner,mass
    well i just took a closer look and noticed that the boot coming off my tb where the clamp is holding it on, the clamp cut into the boot and it has a small leak. Idk if this is def the problem but ima replace the boot and see what happens
  5. #5 Re: Car Bogging :(
    Topeka, KS
    Vacuum leaks will wreak hell on a car.
  6. #6 Re: Car Bogging :(
    gardner,mass
    Well that wasnt it and it seems like its getting worse too. Tomarrow ima try the new filter and see what happens. If that doesnt resolve it ill start narrowing it down to maf ect.
  7. #7 Re: Car Bogging :(
    gardner,mass
    well put in new filter and car seemed to start faster and i went for a quick ride from work to grab a coffee and on the way there i gunned it and it seemed to have more throttle response and didnt bog at all but ill bring it for a real test drive when i get out of work
  8. #8 Re: Car Bogging :(
    Apr 2009
    geary
    My GTP Did the same thing and it was the TB Dirty..
  9. #9 Re: Car Bogging :(
    gardner,mass
    well its running better but still doing it slightly, ima try d/c the maf and running it for a day and see if it does it but it only does it at wot so idk the tb is spotless and i cleaned as far into the sc as i could. What is the sensor coming off the back of the sc on an 04. Is it the tps? i didnt take this off to clean it
    if its not the maf my next step i think ima pull the injectors off and clean them cus idk it kind of seems like it started when i ran seafoam threw it but could be coincidence or maby the seafoam did harm to my new plugs i put in so ill look into that too
    Any other ideas?
  10. #10 Re: Car Bogging :(
    gardner,mass
    hmm i just read another post on how the same problem was traction controll kicking in at wot even if the tires wernt spinning so my question is. Is the tc on when the light is on or off cus the light is always off when i turn the car on so i assumed that meant it was off but then the light shows a line through it so does that meen off? lol if its this ill feel really stupid
  11. #11 Re: Car Bogging :(
    gardner,mass
    well it did it with tc on and off but i did notice how tc reacts cus its slippery today, but is there a way to make it so tc doesnt turn on everytime i start my car its really anoying shutting it off. I decided i would try and clean the maf again and the wiring. Well i noticed like others that when i was trying to connect the wiring back it it was not fitting cus the stupid rubber piece so i tore that out also i notice that one of the spectra rubber ring things actually fell into the filer lol and was probly just getting thrown around in there(i feel dumb) idk how that happened but ya i could imagine that could throw things off due to the maf getting incorrect reading from it getting thrown around lol. but im not to sure if its actually fixed it doesnt seem its doing it like it was but i did get a slight delay at wot but nothing like befor ima bring it for another test drive and probly dc the maf if its still doing it
    But i have another concern and its really worrying me. I was just sitting at my college waiting for my gf to get out and i starting hearing a weird like rubbing sound and could feel it throughout the entire car. Like a waooawoaaoooaowooaa sound lols. Im thinking its the tensioner cus i could hear a slight sound from it befor a clanking when i got the car and im thinking its finnally at that lockup point and needs to be replaced
  12. #12 Re: Car Bogging :(
    Pennsylvania
    90k is about right for pulley bearings to start locking up.
    And for the lower motor mount to explode.
  13. #13 Re: Car Bogging :(
    gardner,mass
    Quote Originally Posted by SlowNA06 View Post
    thankyou for the ****ty info :P
  14. #14 Re: Car Bogging :(
    gardner,mass
    i changed out the bad pully and havnt heard the clicking or felt the rubbing, i also changed the belt and idk if this is why but my car seems to be hotter now(yes i put the pully on the right way) the belt did seem a tiny bit shorter and the pully a tiny bit bigger( its the pully in front of the tensioner) but i cant imagine it should matter. But i took a drive to my sisters after and i seem to have all my power back and everything seems good but after letting the car sit there while i was there for an hour i came back out and started it and the temp gauge went to half instantly and when i drove it went above and its never gone above half befor its always been right below even when pushing the **** out of it
    its not hot out either its raining and ide say about 60
  15. #15 Re: Car Bogging :(
    Pennsylvania
    OH.
    90K is also about the right time for the fan relay to burn up and make the fans intermittent. Check the panel in the fusebox for burn marks. If you find them, all you have to do is clean them and you'll be good as new.
  16. #16 Re: Car Bogging :(
    gardner,mass
    OH.
    will do thankyou sir
  17. #17 Re: Car Bogging :(
    Quote Originally Posted by ginseng View Post
    traction control is ON if the light is off. when you hit the button and the light comes on tc is now turned of, allowing you to spin the tires.
    when you go wot (tc on) even if the wheels are slipping a bit the pcm pulls timing.
    i notice quite a bit more power (feels that way) when i jump on it with no tc and perf shift on.
    with the tc left on i see the low traction light flash even though it dont feel like the tires are breaking loose.
  18. #18 Re: Car Bogging :(
    gardner,mass
    ya but its really annoying having to turn tc off everytime i get in the car ( i have an 04 btw)
  19. #19 Re: Car Bogging :(
    the only time i turn mine off is when i know im going to need all the power, or if its raining. rain is a instant traction control off. or snow.
  1. Bogging
    By goldgp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2011, 01:34 AM
  2. bogging?
    By backinblackgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-28-2010, 05:03 PM
  3. '02 GT bogging down-?
    By Wolf02GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-01-2009, 02:53 PM
