Thread: Fuel Injectors
Results 1 to 7 of 7
  1. #1 Fuel Injectors
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    I would like to know how you are supposed to install the fuel injectors on a 97 gtp motor do i push it in until it stops or what need help
  2. #2 Re: Fuel Injectors
    Topeka, KS
    Pretty much. Make sure they are snug.
  3. #3 Re: Fuel Injectors
    smear some oil on the o ring, they will pop right in for ya.
  4. #4 Re: Fuel Injectors
    Put them in the fuel rail and put the clip on them and then the just set in the heads and bolt to the blower.
  5. #5 Re: Fuel Injectors
    Sep 2012
    bridgeport,NY
    well i dropped the fuel rail assembly on the ground and cracked the plastic on the number 1 injector and bent the return line outlet fitting but installed in anyway no problems but the fuel supply quick disconnect dosent want to hold the line snug im worried that it will leak fuel a while down the road any ideas how to fix
  6. #6 Re: Fuel Injectors
    buy a new fuel rail.
    somebody might have one in the sales section
    Dec 2010
    DMV
    ^this.
    New fuel rail or new engine due to being cheap. Would hate to start a fire just becuz u wanted to save some money.
