I would like to know how you are supposed to install the fuel injectors on a 97 gtp motor do i push it in until it stops or what need help
Pretty much. Make sure they are snug.
Put them in the fuel rail and put the clip on them and then the just set in the heads and bolt to the blower.
well i dropped the fuel rail assembly on the ground and cracked the plastic on the number 1 injector and bent the return line outlet fitting but installed in anyway no problems but the fuel supply quick disconnect dosent want to hold the line snug im worried that it will leak fuel a while down the road any ideas how to fix
